Help with heated seats
#151
The heated seat module is located under the seat.
Fordparts.com is great @ showing where stuff is....
This is for the 2003 Captain chars - I assume other years are the same
I saved the image as a PDF so you could view it, w/o using the link...
Buy 2003 Ford Excursion Parts | FordParts.com
#154
. I took my driver's seat apart and found a broken/burnt wire inside the pad itself. I tried to repair it, that wire has to be the smallest gauge wire and is so small brittle it tool me a while to strip it!
Still no heat, but I am not confidant the wire held. So I am going to order a new heating element.
It takes about 5 minutes to warm up so I guess I did not wait long enough the first time I tested it.
#155
#157
Sure...get the aftermarket kit and install it. Make sure you run a good gauge wire to the heaters to make sure they can handle the amps that the seats draw, but if properly wired in, it's a pretty straightforward install.
#158
i bought one of these to replace my factory heated seat that went bad. everything is included (even the hog ring pliers, but they are worthless, i already had a good set).
http://www.amazon.com/Dorman-628-040...6766445&sr=8-1
you would need to buy 2 of them.
#161
#162
#163
Correct, hit 73 today... back up to about 80 tomorrow...
Cold front over, back to the beach tomorrow!
#164
I could take a picture, but all you would see is stuffed wires and dog hairs...
#165
Worked Great....
well got the drivers working it was just a break in the heating element on the front of the seat.. simple solder and electrical tape and its all good..
im showing you in the picture what wires to check for resistance, if theres continuity its good, if theres no infinaty resistance it has a break in the wire.you can probe this plug after you disconnect it from under the seat and push around on the common areas on the seat with without taking it apart and somtimes you can see where the break is if you push in a certain area and the meter starts reading. both wires are lt blue with pink tracer. the red wire in this pic is just a wire from my meter to fit into the plug since the poker on that probe is busted off.
Good luck its pretty easy though, i suggest checking the resistance before removing the cover just in case its the controller instead..
Ray
Ray
