2002 auto trans problem
Old Aug 30, 2006 | 11:49 AM
seth1's Avatar
seth1
ok... i got a 02 ranger 4.0 auto... and the trans is getting worse and worse, in between 2nd and 3rd gear it slips and the truck revs up and then goes into 3rd. another thing, every once in awhile when i slow down to a stop the trans dont shift down and it will be in like 2nd or 3rd gear, then it will kinda start shifting down while im stopped and it jerks the truck a lil. my dad talked to a guy he works with and he said that ford trans are/were known to have a seal go out above the trans filter, has anyone else heard of this, or have any ideas that could help me out??? thanks for your time
Old Aug 31, 2006 | 03:12 AM
PW01's Avatar
PW01
Sounds just like the problem with my 01. Turned out to be a bad seal on the valve body, they took care of it under warranty. I've heard it is a common problem with these transmissions.
Old Aug 31, 2006 | 08:19 AM
sfcwoodret's Avatar
sfcwoodret
You might also check the torque converter.
Old Sep 3, 2006 | 02:25 PM
seth1's Avatar
seth1
i took the pan off today and there are alot of junks of what appears to be a gasket, and i can see were the valve body gasket as a junk missing out of the back driver side corner, does anyone know how hard of a job it would be to drop the valve body?? thanks seth
Old Sep 4, 2006 | 02:23 PM
Rockledge's Avatar
Rockledge
I've never done it myself, but I have heard it's doable for someone with a little bit of mechanical know-how. You are going to need the Valve Body Service Kit (3L5Z-7M203-JA) and the Valve Body Separator for your application (looks to be 1L5Z-7Z490-BA). See:
https://www.ford-trucks.com/forums/s...2&postcount=19
https://www.ford-trucks.com/forums/3...ing-funny.html
Old Sep 5, 2006 | 07:04 AM
sorensenj's Avatar
sorensenj
Hey Seth, please let us know if replacing the gasket fixes your tranny troubles. I have a 2001 3.0 auto and am curious about some of the tranny problems and solutions people have with them. Thanks.
Old Sep 5, 2006 | 07:42 AM
stuart1's Avatar
stuart1
I own a 2002 with a 3.0 engine.
The transmission had the same complaints at under 10,000km's.
After 6 attempts it is now working good.
Valve bodies are a real problem area.
Old Sep 5, 2006 | 12:32 PM
PW01's Avatar
PW01
The first time mine was fixed they just replaced the gasket. 6 months later they replaced the valve body, all has been well for over 30,000.
Old Sep 6, 2006 | 11:02 PM
seth1's Avatar
seth1
hey PW01, what is the manufacture date on your ranger cuz mine could be close to yours, mines 10/01 but a 02 model. i wonder if its really close then i could have a bad valve body too.. thanks seth
Old Sep 6, 2006 | 11:10 PM
gabebdog1's Avatar
gabebdog1
I am on my 3rd tranny for my 96 ranger 3.0 auto dont know what goes worng with them I do all the regular fluid changes and filters. wish the tranny was as sturdy as the engine
Old Sep 7, 2006 | 03:43 AM
PW01's Avatar
PW01
Seth, if memory serves, mine was built in 05-01
Old Sep 24, 2006 | 11:16 AM
seth1's Avatar
seth1
well i finally got the valve body gasket changed and that didnt solve my problems, my unlce was doin some research and now im goin to be replaceing a valve on the throttle body, its the one that controls the pressure of the fluid, it was 150 bucks and man do i hope thats the problem. i let you guys know if that fixes anything, im planning on doing it today
Old Sep 25, 2006 | 12:07 AM
johnh2000's Avatar
johnh2000
Seth, there is no valve on the throttle body that has anything to do with the
transmission pressure.
Old Sep 25, 2006 | 09:21 AM
seth1's Avatar
seth1
lol my bad, i was in a hurry when i was typing and i meant valve body, theres the ADD kicking in lol
jasoncw
Nov 13, 2013 02:05 PM
l BlAcK l
23
May 4, 2011 07:04 PM
Native Images
6.4L Power Stroke Diesel
Oct 8, 2009 05:37 PM
mikeyw
1997 - 2003 F150
Nov 10, 2005 07:17 PM
Paxdad
Jun 13, 2004 06:45 AM
