No Second Gear in D, OK when Manual Shifting
A couple days ago, my Excursion started skipping 2nd gear when driving in D. The RPMs will go up to 3500 or so before slamming into 3rd gear. Shifting in all other gears works fine. However, when manually shifting through the gears (1, 2, D), it finds 2nd gear and shifts fine.
Does anyone have any ideas on this before I take it to a trans shop? I am mechanically inclined when it comes to engines, but not an auto trans. Thanks in advance for any help.
Jason
Jason
Shift solenoid is easy to replace if you drop the pan. I had Brian at BTS do mine since he had rebuilt the tranny a few months before and I was able to drive it over to him. Took him all of 45 minutes and I was out the door.
The connector to the shift solenoid is at the rear-passenger side of the tranny and comes down from above. With a little work, you can pop it loose from under the truck and check the connections (water, corrosion, etc.) and put it back on. See if it makes any difference.
If you can pull codes, you can look for a "Shift Solenoid B" code (can't remember which one, exactly).
skyler_estes
01-14-2020 10:10 PM
robin22m
03-24-2009 04:31 AM
