6.0 Auto Trans Shift Question
Old Jun 10, 2004 | 04:30 PM
Paxdad's Avatar
Paxdad
Can anyone with a 2004 6.0 PSD 4x4 SC with the 5 speed auto trans. tell me the following:
If you place your transmission in the 3rd gear or 3 position and accelerate from a dead stop does it shift through 3 gears (1>2>3) or does it just start out in 3rd and stay there without shifting. Yesterday, I noticed on mine that when I accidently droped the shift lever into 3rd it was actually in 3rd and did not shift through the gears like I have always been accustomed to with other automatic transmissions. I even tried it in 2nd and 1st with the same result while carrying the rpm up to the usual 3000 rpm shift point, in fact even at redline the trans would not shift.
When placed in Drive 'D' the trans shifts from normally from 1-OD with no problem.
Thanks in advance.
Reid.
Old Jun 10, 2004 | 04:34 PM
bighoss550's Avatar
bighoss550
Thanks in advance.
Reid.
my 03 550 does the same
Old Jun 10, 2004 | 05:11 PM
SBV45's Avatar
SBV45
Thanks in advance.
Reid.
I have a F250 6.0 5 speed auto 4x4 SC. I am pretty sure I put it in 3 and it is in 3 and does NOT go 1>2>3. I will try it on the way home and see if that is the case.
Old Jun 10, 2004 | 06:13 PM
Kowboy's Avatar
Kowboy
While we're talking about this, I am intermittently having a problem when i come to a stop and shift from "D" to "R". there sometimes is a lag in the shift. Like it takes a second to hit reverse. Almost like its low on fluid. (checked the level and its ok) Anyone else having this problem or has any Ford Technician out there run into this concern? Thank you in advance for any help given.
2004 F350
FX4, PSD, 6.0l
Old Jun 10, 2004 | 06:40 PM
Buzz Cut's Avatar
Buzz Cut
ok with the torqshift if you select 1,2 or 3 that is the gear you get no shifts occur, The tranny acts just like a manual tranny in that respect. D gives you 5 up or down shifts, Tow haul changes shift RPM and locks the torq converter.
yes most truck will have a short lag time going from D [or any other forward gear] to reverse, more than 1-2 seconds is not normal however.
Old Jun 10, 2004 | 08:00 PM
Cowboy Brett's Avatar
Cowboy Brett
Man, I never noticed that lag before. It doesn't do it all the time for me though.
I think that it is probably a safety feature to stop you from engaging reverse while you're still going forward. The older E4ODs (1992~1995) had a really long pause between reverse and drive that got shorter as technology marched onward. As a result I am conditioned to coming to a full stop, shifting the lever, and waiting until I feel the gear kick in. I was told by the parts people at Ford that the delay was added in the E4OD (now its been revised and rechristened the 4R100. Torqshift is 5R55 I believe) because shifting from R to D if the truck was moving in the oppopsite direction led to premature failure.
This is just shooting from the hip, but I think if you make it a pointed goal to completely stop dead in your tracks it'll pop right back and forth all day. I'm not 100% sure, but I'll give it the evil eye over the next few days.
Old Jun 10, 2004 | 08:59 PM
twoballsleft's Avatar
twoballsleft
Funny you mention the shift to reverse...I back into my driveway every time I park. Mine almost bangs into reverse from drive...I pull up, stop, and put it into reverse and it imeadiatly grabs. I thought it was just the way the 5spd was...nice n tight.
And yes, mine does the same in 3rd...stays there....good for snow and ice.
2004 350 psd 5spd 950miles
Old Jun 12, 2004 | 01:10 AM
chefbuba's Avatar
chefbuba
Thanks in advance.
Reid.
I have an 04 6.0 4x4 sc 8' bed , have had it for 2 weeks, at 442 miles trans started slipping, ran it into the dealer to have trans fluid checked, (thought maybe it was not checked in pre delivery) but was on the money,,,got worse after i shut it down and then tried to move it out of the service bay,,,,,,no forward ,no reverse. Had a bad shift solonoid. dealer reoplaced and no trouble so far.
My only question is who is going to pay for my rental??? Selling dealer says "have the repairing dealer take care of that", repairing dealer says "selling dealer should take care of that"....Good luck!
Old Jun 12, 2004 | 06:36 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Buzz Cut hit it right on
Old Jun 12, 2004 | 08:19 AM
SBV45's Avatar
SBV45
You don't automatically get a rental unless you have an extended warranty program. After that it is up to the dealer if they want to give up a loaner. The default postion by the dealer is no. Fortuneately, mine has only spent overnight once.
Old Jun 12, 2004 | 10:02 AM
jdadamsjr's Avatar
jdadamsjr
Yep - up to the dealer....
but I've got the extended warranty and a great dealer as well (so far)
So back to the tranny then ----
Sounds like we have an Auto-manual then :-)
can put it in gear and leave it there or shift on our own !!!
Way cool for all that Texus ice and snow then to lessen the starting torque !
Old Jun 12, 2004 | 11:50 PM
BJ_Hawk's Avatar
BJ_Hawk
Hopefully that will help alot of the Texas drivers out there! I spent 7 years at Ft. Hood and hated it; driveing into post with all the locals acting like bumper cars! haha lol I'm being reassigned there at the end of the month, so I guess I better be nice. Found fuel here in El Paso for 1.69 today.
Old Jun 13, 2004 | 12:27 AM
SBV45's Avatar
SBV45
It's a $1.609 in Round Rock today!
Old Jun 13, 2004 | 01:53 AM
jdadamsjr's Avatar
jdadamsjr
Actually used that feature a lot today...
building a house and have to play driver while my wife decides on brick and stone and mortar colors (even though we've built before - she still has to "start over" )
but idling around the upscale neighborhoods just put it in thrid and it was a LOT easier on the fuelage and noise level...
a lot fewer people thought we were "casing" their houses to rob them
Course when we had to pull the mini-dvd out and video them so she could remember them
Old Jun 13, 2004 | 06:45 AM
IB Tim's Avatar
IB Tim
Those two sure go together……..that neighborhood is still talking about you guys
Prototypemech
Dec 24, 2013 10:05 PM
jasoncw
Nov 13, 2013 02:05 PM
Native Images
6.4L Power Stroke Diesel
Oct 8, 2009 05:37 PM
w8jumper
Jan 18, 2007 08:00 PM
TRKR_MAN
Mar 3, 2004 11:10 AM
