Keyless Keypad Code
Old May 10, 2009 | 11:06 AM
  #451
vettdvr's Avatar
vettdvr
Originally Posted by lynsta
EXV10 reminded us of the hacking option. I think this means using the chart to test the numbers. I appreciate the reminder. I do have that post earmarked. I am reserving that option for last, because I do not understand how to use the chart. Lynsta
the way I used the chart:
If you have not disconnected the battery as in my previous post you might just find a previous owner code. So disconnect all batteries for about 15 minutes to allow the security to reset to the factory setting.
Throw out all simple #'s. 11111 33333 12345 etc.
Then I started in the middle of the sheet and worked to the front.
Consider each button to be 0,1,2,3,4 forget the 5,6,7,8,9
After each attempt press 34 together to lock the doors which will clear any previous trial.
Old May 10, 2009 | 01:04 PM
  #452
EXv10's Avatar
EXv10
Just punch all the #'s in and when it opens backtrack 5 places.
Old May 11, 2009 | 02:37 PM
  #453
1's Avatar
Here's a lil tutorial with pics on where to look and my method for seeing the sticker. I threw this together after a good tip from another member on here. The pics seem to really help with knowing what to look for.
https://www.ford-trucks.com/forums/6...er-method.html
Old May 14, 2009 | 07:53 PM
  #454
cexcursion00's Avatar
cexcursion00
Could someone send me the code sheets please? I am new at this sight. cumminspower@comcast.net
Old May 14, 2009 | 09:31 PM
  #455
EXv10's Avatar
EXv10
Here it is;
Weak security in our daily lives@Everything2.com
Old May 17, 2009 | 12:33 PM
  #456
al52269's Avatar
al52269
Door Code Location...
I actually found the door code behind the fuse box area (Driver Side) on my brother’s 2000 Ford Expedition EB. There is a big white sticker with 5 numbers starting with number 1####. Hope this helps...
Old May 17, 2009 | 02:39 PM
  #457
EXv10's Avatar
EXv10
That's great but I don't think they put them on the 2000 and '01 Ex's
Old May 17, 2009 | 03:23 PM
  #458
medic152's Avatar
medic152
Door Code
I had the same problem on my 2000 EX. After looking all over under the dash for it I took it down to the local dealer and they hooked it up to the computer and had my code in less than 5 minutes. They didn't charge me to get it either.
Brad
Old May 20, 2009 | 10:43 PM
  #459
motopsyko32's Avatar
motopsyko32
need the cheat sheet please...
motopsyko32 AT bellsouth dot net
Old May 20, 2009 | 11:24 PM
  #460
EXv10's Avatar
EXv10
It's on post 455 above here.
Old Jun 7, 2009 | 03:48 PM
  #461
KeystoneHomeOK's Avatar
KeystoneHomeOK
I just bought a 2001 Expedition XLT with no manuals and I had no way how to find the keypad code. Using the info from this thread I went out to the driveway, looked at the firewall behind the fuse panel, and there it was!
Thanks for all the good info!
Troy
Old Jun 7, 2009 | 04:35 PM
  #462
EXv10's Avatar
EXv10
That dispells my theory about no #s on the 00 and 01. Maybe they started putting them on in late '01.
Old Jun 7, 2009 | 10:30 PM
  #463
KeystoneHomeOK
It may also be the difference between the 1/2 ton and 3/4 ton chassis. Just my 2cw....
Old Jun 7, 2009 | 10:35 PM
  #464
EXv10's Avatar
EXv10
I didn't see that you had an Expy.
Old Jun 20, 2009 | 10:41 PM
  #465
Scottwoo's Avatar
Scottwoo
Mine was behind white insulation looking stuff...easier for me to find throught the trash bag holder. used screwdriver to move the insul and it was upside down.
