Electronic shift control
Old May 20, 2006 | 01:26 PM
oldzinner's Avatar
oldzinner
I have a 1994 Explorer and when trying to engage 4 wheel drive nothing happens. My mechanic said to try a used shift control from the junkyard as all systems (module & transfer case) check OK so far. Is it possible the switch is bad ? Is there something else to try ?
Thanks for your input.
Old May 20, 2006 | 01:59 PM
aquanaut20's Avatar
aquanaut20
http://draco.acs.uci.edu/explorer/tcase.html
Old May 20, 2006 | 02:21 PM
oldzinner's Avatar
oldzinner
There is no clicking sound from the module and the test indicates it's Ok according to my mechanic.
Any ideas ?
Thanks
Old May 20, 2006 | 04:05 PM
aquanaut20's Avatar
aquanaut20
the module will click even if the motor does not turn, my bet, the shift motor on the T/C need some TLC.
After you fix the shift motor, go see your mechanic and teach him how to diagnose an EXPLODER.
Old May 20, 2006 | 07:32 PM
oldzinner's Avatar
oldzinner
The mechanic just put a new motor on it and said he tested all the circuits, but the electronic control switch tests ok but fails when the button is pushed.
I'm not electronics literate so am at a loss on what to look for or do.
What do you suggest that I could try.
Thanks for your help.
Old May 20, 2006 | 10:55 PM
aquanaut20's Avatar
aquanaut20
The control module may be confused, disconnect the battery for 20min, reconnect and try, remember for 4x4L, brake must be depressed and in N
Old May 21, 2006 | 01:39 PM
Baumer's Avatar
Baumer
Try to change it in Neutral. Put the gear in Neutral and hold your foot on the brake and then push your button! it worked for me.
Old May 21, 2006 | 03:08 PM
oldzinner's Avatar
oldzinner
Baumer, thanks for the tip, but it did not work.
This is frustrating. There must be a way.... just have to find it.
Old May 21, 2006 | 03:43 PM
MisterCMK's Avatar
MisterCMK
If you don't even hear any relays clicking its most likely the switch or the control module. If its the motor, you will still hear the relays clicking.
Old May 24, 2006 | 03:32 PM
oldzinner's Avatar
oldzinner
Tried a used switch without any luck. Maybe it's time to get that newer Mountaineer I always wanted.
Thanks to all for your input.
Old May 24, 2006 | 04:49 PM
aquanaut20's Avatar
aquanaut20
have you actually applied 12dc directly to the motor?
Old May 24, 2006 | 09:41 PM
oldzinner's Avatar
oldzinner
I'd have to ask my mechanic that one. He's the one who has the expertise, I just pay the bill but wish I knew more about this.Will follow up and let you know.
Thanks
Old May 30, 2006 | 07:25 PM
leisureman's Avatar
leisureman
Smile
Thank you all who tried to help me.
I've decided to trade the Explorer in for an 02 Mountaineer and enjoy something newer.
Jonathan Stone
General Automotive Discussion
Mar 8, 2022 05:52 PM
Luvmifordpu
18
Nov 24, 2015 06:23 PM
joegeds
Mar 27, 2015 05:26 PM
billdavis538
1997 - 2003 F150
May 12, 2014 08:26 PM
84espy
Nov 18, 2013 08:54 PM
