General Automotive Discussion
F150 stalls in reverse
Old Jul 21, 2015 | 07:50 PM
Jonathan Stone's Avatar
Jonathan Stone
I have a 1994 automatic F150 5.0 4x4 with dual tanks and I have been having trouble with reverse. Occasionally I will shift into reverse and the engine will start to putter and if I don't press the gas pedal it will stall out. Its almost like trying to drive a stick shift. It doenst do it every time but probably 60% of the time it will do that. I heard maybe it could be the transmission filter? Maybe idle air control? Any answers will be wonderful.
Old Jul 21, 2015 | 08:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Low trans fluid is the most common cause of this.
Old Jul 21, 2015 | 08:37 PM
Jonathan Stone
The transmission fluid is full..
Jonathan Stone
Old Jul 22, 2015 | 12:03 AM
Jonathan Stone
Update: I cleaned iac valve which was very dirty, started her up and I can tell it runs smoother and doesn't stall in reverse anymore. Except when I shift to reverse it seems to kick into gear hard.. I don't know if this matters but what do y'all think?
Old Jul 22, 2015 | 12:39 AM
Jonathan Stone
I found that I am idling at 1500 rpms. That is why I am shifting hard. How do I tune that down?
Old Jul 22, 2015 | 07:03 PM
Mark Kovalsky
Usually by replacing the IAC.
Old Mar 8, 2022 | 05:52 PM
RMiranda's Avatar
RMiranda
Trailering
Hey Jonathan did you ever solve this???
My truck is stalling when put in reverse.
Helppp
KAT_Ayanami
Mar 8, 2022 06:04 PM
RadioControlGuy85
Jan 30, 2016 03:25 PM
kilich
Apr 19, 2013 02:12 PM
chrison600
Oct 13, 2012 12:56 PM
