transfer case question
Old Mar 26, 2015 | 03:00 PM
joegeds's Avatar
joegeds
What holds the control rod onto the shift lever? I can't get that separated. It isn't anything you unscrew. I tried prying it apart with a screw driver, but don't want to break it - after much force, it still won't separate. The manual just says to make sure you do it gently so as not to damage the gearshift lever.
Old Mar 27, 2015 | 09:10 AM
jas88's Avatar
jas88
There are plastic bushings that go over a conical shaped peg. They are much harder to get off than on. I use a big pair of channel-locks and squeeze them off.
Old Mar 27, 2015 | 09:28 AM
bashby's Avatar
bashby
Pry harder.
Old Mar 27, 2015 | 05:26 PM
joegeds's Avatar
joegeds
Yeah, I finally got them off. I really thought I was going to break something. Weird that the manual specifically says to disassemble them very carefully to prevent damage, yet the only way to disassemble them is the almost break them.
Razkid
Jan 22, 2017 11:18 AM
17fordguy
Jun 9, 2009 08:15 AM
fooch37
1997 - 2003 F150
Apr 10, 2006 11:42 AM
BroncShane
1978 - 1996 Big Bronco
Feb 23, 2004 02:11 PM
optikal illushun
Oct 2, 2003 08:44 PM
