Timing degee change
Old Mar 30, 2006 | 11:13 PM
78fordranger's Avatar
78fordranger
Timing degee change
If I put a new timing chain set on and set it at o degrees would I feel any power difference in a stock 400 there is no mods on it yet. but I keep hearing about the timing being set off.
Old Mar 30, 2006 | 11:31 PM
Torque1st's Avatar
Torque1st
Posting Legend
Your timing set is probably old and needs replaced anyway. Replacement is required after 80K miles. The worn timing chain is retarding the cam timing some additional amount. It will make a real difference to get the cam timing set properly. Just get an aftermarket timing set that can be installed straight up. ALL of the OEM style sets are retarded regardless of year.
Old Jul 15, 2006 | 09:36 AM
bad79bronco's Avatar
bad79bronco
I Just Bought A Timing Set From Autozone It Does Not Have Mult Keyways , Is The Set Without Mult Keyways Have 4 Deg Built In
Old Jul 15, 2006 | 09:47 AM
mark a.'s Avatar
mark a.
Depends on the year of set you bought. Order one for a '70 351c, it will be a 0 deg. set.
Old Jul 15, 2006 | 01:27 PM
havi's Avatar
havi
I'll have the Roast Duck
to verify, installing a 0 degree timing set without a cam change will increase power? my timing set broke in my 351M, and I need to replace it, but eventually I'll be doing more mods, but I'd like to just install the timing set for now, so I can move it out of the garage. So is this feasible? Not hijacking the thread just wondering the same thing.
Old Jul 16, 2006 | 09:01 AM
mark a.'s Avatar
mark a.
If your going to change it I would change it to 0. You probably wont notice much, but the enging will be better off.
Old Jul 16, 2006 | 09:14 AM
havi's Avatar
havi
good enough for me. I just wasn't sure if the 0 degree change would screw up the cam.
ford_0004
Mar 29, 2010 07:03 PM
74highboy
Feb 1, 2010 06:40 PM
billg302
70
Dec 30, 2008 02:12 PM
doubletree
Dec 2, 2004 08:10 AM
jb666
Jan 4, 2004 08:30 PM
