390 cam timing
Old Jan 25, 2010 | 06:42 PM
74highboy's Avatar
74highboy
390 cam timing
i just bought a 3 key timing set and was wondering what would be better, to set it at 0 or advance it 4 degrees?
Old Jan 25, 2010 | 07:57 PM
fordeverpower's Avatar
fordeverpower
depends on cam, motor and usage, but most likey 4 degrees advance would be ok,moves peak tq and power arond 400 to 500 rpm lower and lowers peak horsepower.
Old Jan 25, 2010 | 08:07 PM
74highboy's Avatar
74highboy
well its all stock except for the edelprock performer intake manifold, im trying to wake this thing up a little its kind of a turd.
Old Jan 25, 2010 | 08:30 PM
85e150's Avatar
85e150
If it's a low-compression truck motor, you might wake it, but it will still be drowsy...
FE's usually get enough in, it's the out that's the problem. Got headers?
And the usual question--are you sure it's a 390? Check that stroke.
Good luck with it. There is a monster inside there, you may just need a little more fiddling.
Old Jan 25, 2010 | 10:09 PM
74highboy's Avatar
74highboy
no headers, does it make that big of a difference? i cant say for certain its a 390 i know it came with a 360 but the guy i bought it from said a rebuilt 390 was put in a few years back.
Old Jan 26, 2010 | 01:23 PM
85e150's Avatar
85e150
Headers make a big difference in power output. Any FE performance build requires them.
If you really just want a low-rev puller, they aren't that critical, but you should do the dual exhaust, crossover pipe etc or equivalent larger pipe to eliminate as much restriction in the exhaust as possible.
Old Jan 26, 2010 | 01:44 PM
montana_highboy's Avatar
montana_highboy
As sure as the sun will rise tomorrow all 360's magically become 390's on sales day, you have to measure the stroke.
Old Jan 26, 2010 | 02:53 PM
74highboy's Avatar
74highboy
it already has a dual exhaust on it but each side is isolated, does the h-pipe make that much difference? ill measure the stroke best i can through one of the plug holes today.
Old Feb 1, 2010 | 06:40 PM
71_4x4_390's Avatar
71_4x4_390
Hey! Mine started out life as a lowly 360, but it has magically become a 390 and it ain't for sale!
Crossover pipes are highly recommended.
Old Yblockman
May 17, 2017 02:18 PM
RockWVU
Apr 14, 2012 02:33 PM
xdevdogx
Aug 15, 2011 05:21 PM
justin_brandstein
Mar 26, 2009 02:39 AM
billg302
70
Dec 30, 2008 02:12 PM
