Oil pressure
Old Jul 13, 2006 | 04:38 PM
77ford guy's Avatar
77ford guy
Talking Oil pressure
Hey! I got a 351m. When i start it, the oil pressure is about 75, but after a little running it drops to 25. Is this a good pressure? If it gets lower than 25 what might be wrong? Thanks!
Old Jul 13, 2006 | 08:02 PM
danlee's Avatar
danlee
As oil heats up it gets thinner. When it thins some of the oil leaks past the bearings and the pressure at the gauge drops. 25 lbs pressure at idle when hot is GOOD pressure. Are these numbers oil pressure at idle or when running on the highway?
Old Jul 13, 2006 | 09:09 PM
77ford guy's Avatar
77ford guy
THat is at an idle. What would bad oil pressure be? Thanks for your help.
Old Jul 13, 2006 | 09:13 PM
danlee's Avatar
danlee
Bad oil pressure is when your valves tap at idle when the engine is hot.
Old Jul 16, 2006 | 06:12 PM
53fatfndr's Avatar
53fatfndr
When hot and cruising down the road, my oil pressure is around 50-55 psi and sits around 25-30 at idle. Your pressure sounds fine to me
alwayschooseford
Dec 12, 2010 09:25 PM
larryplummer
21
Feb 12, 2005 06:35 AM
kitsapcountychopper
15
Apr 28, 2004 11:47 PM
smokinstroker
Jul 21, 2003 01:44 AM
Dave Legg
Jul 25, 1999 10:04 AM
