8.7mpg
Old Apr 1, 2006 | 11:09 AM
  #91
Kwikkordead's Avatar
Kwikkordead
I used a gauge on the end of a long piece of fuel line. Hang the gauge off of the rear view mirror and go drive it.
Old Apr 1, 2006 | 11:17 AM
  #92
bloomy63's Avatar
bloomy63
i checked mine by making up a hose long enough that attached to the 1/8 inch npt port in the head attached a 0-100 psi gauge to the other and duck taped the gauge to my windshield ( in an area that i could see while i was driving and did not obstruct my view) then went out to the biggest hill i could find and put the petal to the floorboard. probally not the sefest way to check the pressure, but it worked for me. the hose that i used was small enough that the weather stripping flexed enough that i could close the hood
Old Apr 1, 2006 | 11:20 AM
  #93
Kwikkordead
And what was the reading that you came up with?
Old Apr 1, 2006 | 11:26 AM
  #94
Jerrod's Avatar
Jerrod
So where can i pick up a cheap gauge that is suitable to do it using the "windshield" method?
Old Apr 1, 2006 | 11:46 AM
  #95
PSNut's Avatar
PSNut
Here:
http://www.jegs.com/webapp/wcs/store...0267&langId=-1
With some SAE30R7 multi-fuel fuel line for fuel injection.
Nut
Old Apr 1, 2006 | 11:57 AM
  #96
Jerrod's Avatar
Jerrod
Do local stores normally carry a suitable gauge? Such as autozone or the like?
Old Apr 1, 2006 | 12:23 PM
  #97
PSNut's Avatar
PSNut
I believe yes but Doesn't hurt to call...i'm one to forget to call.
Old Apr 1, 2006 | 12:26 PM
  #98
Jerrod's Avatar
Jerrod
PS Nut,
Did you see my post on sticking EBPV?? Any thoughts?
Old Apr 1, 2006 | 12:27 PM
  #99
PSNut's Avatar
PSNut
PS Nut,
U must have read my mind...i'm thinking about it right now.
Old Apr 1, 2006 | 12:36 PM
  #100
bloomy63's Avatar
bloomy63
my readings were at idle 55 psi, underload 35psi
Old Apr 1, 2006 | 12:39 PM
  #101
PSNut's Avatar
PSNut
bloomy63...can u fill out your signature for future use in helping u? I would pull the lift pump and clean the inlet screen then check again.
Nut
Old Apr 1, 2006 | 12:54 PM
  #102
Kwikkordead
Originally Posted by PSNut
There's your pre pump pump for pushing fuel thru
i nice MG inline fuel filter.
Nut
I took a different approach - I moved the pump back to the top of the fuel tank with plans to run the fuel level down and relocate the pump to the inside of the tank at the end of the pickup. I'll jam the pickup screen over the inlet of the pump and attach it to the bottom end of the pipe pipe feeding out. It should be a cinch of a mod. For now it works a lot better than the stock location, but I still get those little mad bee sounds first thing in the morning if it's below freezing and I have B-50 in the tank. Relocating the pump to the rear of the truck cut the buzzing in half, but not eliminating as I had hoped. So it's going inside the tank.
I'll post pictures when it get's done. Not for a while, I have too many other things I need to get done first, so this one is many months away if not a couple of years.
Old Apr 1, 2006 | 12:57 PM
  #103
PSNut's Avatar
PSNut
Dang...that's groovy Kwik. Lots of idea's going around here. Why didn't Ford think of that one? Hmmmm.....
Nut
Old Apr 1, 2006 | 01:16 PM
  #104
bloomy63's Avatar
bloomy63
ps nut, my truck is fixed, my problem was my fuel pump it was bad. i was replying to kwick's question of what my readings were when i found my problem, sorry for any confusion i might have caused. i filled out my signature, hopefully it works
Old Apr 1, 2006 | 01:20 PM
  #105
PSNut's Avatar
PSNut
Excellent!
