8.7mpg
Old Mar 27, 2006 | 11:31 PM
  #31
cangim's Avatar
cangim
Originally Posted by foodog2
I was getting milage like that and my mechanic tightened up every hose clamp on the turbo and I got about 1 MPG per clamp. I also needed a map sensor. The mechanic did not just run the computer he actually was reading voltages and levels of a bunch of stuff.
Awe intersting, didn't think about that, if the map sensor is bad and showing high boost, it could in theory dump more fuel, but you would still see smoke if that is the case. Definately something to look into though.
Does the truck roll pretty easy when in Neutral? On flat to very slight decline, I can push mine myself at the door. Also, what about tires, inflated properly? Are they the right size? if not has the speedo been re-cal'd to show proper speeds? I use the mile markers on the interstate and get a 5 marker average, i.e. if on 3 at the post, look down again in about 4-5 minutes to see if the posts are still at 3. It would have to be quite a ways off to error calculations that much though.
Old Mar 28, 2006 | 06:43 AM
  #32
BowDown's Avatar
BowDown
Ya, I should really check tirepressure. I had new tires installed after tank #2. Hmm...
Truck will coast pretty far once I let off the gas. I don't think theres any real resistance there.
Map sensor eh? That might be tough to diagnose...
Old Mar 28, 2006 | 07:09 AM
  #33
BowDown's Avatar
BowDown
Should I have a cat on my 2000 CC Dually SB? I dont remember seeing one.
Maybe the muffler is stopped up?
Old Mar 28, 2006 | 08:08 AM
  #34
Kwikkordead's Avatar
Kwikkordead
Some did, some didn't. You just have to roll under and look. A restricted exhaust would explain the high EGT's as well.
Old Mar 28, 2006 | 09:48 AM
  #35
wolftan's Avatar
wolftan
I would try an additive.....maybe bad gas too?
Old Mar 28, 2006 | 10:26 AM
  #36
BowDown's Avatar
BowDown
Well if I put gas in, I would be in trouble. LOL
I put an additive every time. I just tried a new kind on the 4th fillup. No change. If anything worse.
Old Mar 28, 2006 | 10:30 AM
  #37
Tenn01PSD350's Avatar
Tenn01PSD350
Take a look at my recent PCM post. Your problem may be related, I don't know as I'm trying to figure this out too. Good luck.
Old Mar 28, 2006 | 11:02 AM
  #38
wolftan's Avatar
wolftan
what about that icp fuel sensor....not sure what happens when those things go out....you can buy those from ebay for about $40
Old Mar 28, 2006 | 12:03 PM
  #39
zx250's Avatar
zx250
Of the next Riffraff East
What kind of RPMs are you showing at highway speeds? Say 60 and 70mph. Do you know what gears you have? I just went to 315s on my truck and my speedo is off around 10%. I would guess that my odometer is also off that much. That still wouldn't account for that much differance in you mileage. What about your front hubs? Are you sure their not locked?
Old Mar 28, 2006 | 01:28 PM
  #40
BowDown's Avatar
BowDown
I'm sure they arent locked now. Night and day difference between the 2.
So things I should check.
Tire pressure
Boots
Muffler?
Exhaust Flag Thingy
CPS?
Old Mar 28, 2006 | 01:32 PM
  #41
zx250's Avatar
zx250
They could be locked and 4 wheel drive not engaged. Not so easy to tell. What about your rpms?
Old Mar 28, 2006 | 02:15 PM
  #42
BowDown's Avatar
BowDown
Hmm... I will have to check to get an accurate number. I believe that when I'm doing 55 im at about 1800.
Old Mar 28, 2006 | 02:54 PM
  #43
BowDown's Avatar
BowDown
4 rear tires were 55lbs... front passenger was 52lbs.. front driver was 42lbs!
Wow, hope I dont have a leak. New tires were mounted like 3 weeks ago at ford.
I filled all to 70lbs per mechanics suggestion.
Old Mar 28, 2006 | 03:07 PM
  #44
cangim's Avatar
cangim
Depending on tire, I would stay at 55 if you are not loaded, you can check the hubs for sure by turning the front driveline by hand when not engaged. If on is engaged, it will be difficult to turn and you can see which one doesn't rotate with the drive line.
I am doing right at 70 @ 2000 rpm, haven't really driven 55 mph lately, I have 3:73 gearing. Your 2000 probably doesn't have a Cat, but the stock muffler really restricts the flow. Have you disconnected batteries to reset the PCM. Probably won't make any difference though.
Old Mar 28, 2006 | 03:09 PM
  #45
BowDown's Avatar
BowDown
I know the hubs are in AUTO mode. They were locked when I first got it, and I had to take the handle of a pair of channel locks to use as a key to turn em. I couldn't turn em with my hands.
