BB headers
Old Mar 14, 2006 | 09:39 PM
BIG66PROJECT's Avatar
BIG66PROJECT
Thumbs down BB headers
Who make s a good set of headers that will fit my 429CJ in my 66 F-100 I would like ceramic coated instead of chrome and 3" collectors thanks Chad
Old Mar 14, 2006 | 10:12 PM
FordBoypete's Avatar
FordBoypete
L&L Products in Texas make good headers for your 385 series into a 65-79 FoMoCo "F".
FBp
Old Mar 14, 2006 | 10:40 PM
BIG66PROJECT
Thanks for the info they didnt show my application so I emailed them.One more question does my F-100 come with a factory 9"
Old Mar 14, 2006 | 10:48 PM
BobbyFord's Avatar
BobbyFord
It should, unless someone changed it. Check axle code.
Old Mar 14, 2006 | 11:07 PM
Putt's Avatar
Putt
It is easiest to just look at the axle, if there is NOT a removeable cover, it is a 9". The vast majority have the 9" axle.
Old Mar 14, 2006 | 11:36 PM
BIG66PROJECT
yep no diff cover now I need to find some gears and a locker
Old Mar 14, 2006 | 11:41 PM
Putt's Avatar
Putt
Those are easy to find for the 9", but you will need to know if you have 28 or 31 spline rear axles...and no you can't just switch the axles, they are a different diameter at the wheel bearing location. I would bet you have the 28 spline if it is original.
You can get any gear ratio you could possibly want for the 9", it uses the same carrier no matter what ratio it is. Lots of choices for a limited slip also, Detroit Locker, Eaton, Auburn, Loc-Rite. PowerTrax, just take your pick!!
Old Mar 15, 2006 | 04:53 AM
jowilker's Avatar
jowilker
Chad, There was never a 429 installed in a F series pickup, so there is no app for it. The reference that Pete made was for a 460 (aka 385 series) (late 70s). He runs one in his truck.
maybe this will help a little
John
Old Mar 15, 2006 | 08:07 AM
BIG66PROJECT
Smile 460/429
Im pretty sure that 460/429 are the same motor on the outside its just the bore and stoke, the block size is the same don't quote me on that but that is what I have beeen told.intake manifolds geardrives and numerous other parts are interchangable
Old Mar 15, 2006 | 04:31 PM
BobbyFord's Avatar
BobbyFord
The only difference with the 429 and early 460s is the crank and the pistons. The bore is the same. Head configuration is the same.
Mikes '66
Dec 3, 2013 07:31 PM
Mikes '66
Dec 3, 2013 02:25 PM
trav54
Mar 10, 2010 06:52 PM
1966 f-100
Dec 9, 2007 12:26 PM
junkyardjeff
Jul 21, 2005 09:49 AM
