66 with 460 what headers???
Old Mar 4, 2010 | 10:45 PM
trav54's Avatar
trav54
Hi i put a 460/c6 in my 66 swb 2 yrs ago and used the LMC engine mount kit, was wonderin if anyone has used these mounts with headers and what brand and style worked the best thanks
Old Mar 4, 2010 | 10:49 PM
fatdan460's Avatar
fatdan460
check with land l they make 460 swap headers for all kinds of applications. i dont know if they cover 60's but for sure 70's 2 and 4 wheel drives
Old Mar 9, 2010 | 08:23 PM
trav54's Avatar
trav54
Thanks L&L doesnt offer anything for 65-66, just 67 and up, wonder if 67 would work with a little work?
Old Mar 9, 2010 | 09:14 PM
fatdan460's Avatar
fatdan460
sorry man. wish i could've sent you straight. i didn't think they went back that far
Old Mar 10, 2010 | 08:59 AM
banjopicker66's Avatar
banjopicker66
Trav54: The front end dimensions of '65 - '79 2WD trucks are the same. My '66 2WD has a 460 installed using the factory 3-piece engine perches and motor mounts from a '78 F-250. They bolted right up, as the frame dimensions and positioning of the frame holes are identical throughout those years.
If you had used the factory motor mounts, you would be able to use stock or factory headers.
If you can compare the measurements of your LMC mounts and your 460's geometry and positioning with a stock 460 setup, you should be able to tell if stock headers will fit. I rather think they will, and believe the most likely issue will be if the LMC mounts put the engine too low and close to the frame.
Old Mar 10, 2010 | 06:52 PM
RocketMonkey28's Avatar
RocketMonkey28
I agree with BanjoPicker. I have the stock motor mounts/towers from a later truck, and I think your kit puts the motor in a diff place. I've checked, and it appears the later, up to 79 460 headers would fit with factory mounts, but couldn't say for sure about yours. Where are you? Maybe if there is someone in your area, you could measure theirs and yours. Does LMC offer any info about factory engine placement?
mxer0022
Oct 16, 2016 11:14 AM
hwyhogg
Sep 5, 2016 07:57 PM
Northern Caveman
1978 - 1996 Big Bronco
Apr 19, 2012 06:11 PM
66f14evr
British Columbia
16
Nov 6, 2004 10:37 PM
4wheeling79
Oct 26, 2003 04:36 PM
