looking for the eot sensor
Old Feb 27, 2006 | 06:03 AM
modified8's Avatar
modified8
on a 95 psd i was woundering where the eot sensor is.thanks
Old Feb 27, 2006 | 08:41 AM
1997F-350's Avatar
1997F-350
pretty sure its the one that is on the back of hpop reservoir. shares the same wiring as icp and ipr if im not mistakin.
Old Feb 27, 2006 | 09:04 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Yep. The one on top of the reservoir is the oil pressure switch, and the rear facing one is the EOT sensor.
Old Feb 28, 2006 | 07:30 PM
modified8's Avatar
modified8
thanks for the imfo.i got some wierd scanner numbers on the ipr.its building 2800psi at 35 % at 2200 rpm.falls flat on its face and starts to smoke and run rough. the thing starts and runs good until 2200rpm.any ideas? thanks
Old Feb 28, 2006 | 07:41 PM
Kwikkordead's Avatar
Kwikkordead
There's been a lot of posts stating that a ground wire to the back of the IPR gets loose and then the truck runs bad.
Old Feb 28, 2006 | 09:46 PM
cookie88's Avatar
cookie88
FTE Emeritus
Is that with a chip installed or without?
Old Mar 1, 2006 | 05:05 AM
modified8's Avatar
modified8
with out chip.we got 3 of these trucks for work and another 1 come in last night with same prob.now i got 2 trucks down.took 3rd truck out and drove run like a champ.so i switched idm no change.i guess its one of those days! is any way to test the ipr.thanks
Old Mar 1, 2006 | 05:13 AM
bilder12's Avatar
bilder12
Must be halloween where you live ... 4 of them with the same problem. Does it sound like a fuel supply problem? Filter I mean.
Old Mar 1, 2006 | 06:49 AM
Kwikkordead
Try changing your oil if it's been a while. Many posts stating that whatever driveability problem they had was cleared up with an oil change.
Old Mar 1, 2006 | 07:27 PM
cookie88's Avatar
cookie88
FTE Emeritus
Any codes stored?
Old Mar 3, 2006 | 07:28 AM
modified8's Avatar
modified8
just thought i would give you a update on what i found wrong.the first truck had a bad eot senser .the 2nd truck had the wrong ipr senser in.some other shop worked on this a while ago .amagin that.but anyway i got it to run pretty good. the o-rings are stating to leak but thats another day!thanks for all your help and good info on this site.thanks mod8
andy's2000
26
Nov 6, 2016 08:42 PM
Bigdogca1966
Apr 24, 2016 10:23 AM
bookem15
Jun 2, 2015 10:04 PM
andy's2000
20
Mar 15, 2015 05:56 PM
hndacr
Jun 2, 2010 08:31 AM
