EOT sensor pigtail
Old Apr 13, 2016 | 08:38 PM
Bigdogca1966's Avatar
Bigdogca1966
EOT sensor pigtail
Ok.. I ordered the EOT pigtail only for it to arrive and be the wrong one. Dealership can have it by tomorrow but Napa and other auto parts store cannot order it.. What the hell.. I will have to get it from the dealer then cut the connector and splice and heat shrink it..
Old Apr 13, 2016 | 08:58 PM
AllaboutMPG's Avatar
AllaboutMPG
quick internet search found this
7.3L Engine Oil Temperature Sensor | Pure Diesel Power
http://puredieselpower.com/ford/ford...r-pigtail.html
Old Apr 13, 2016 | 09:28 PM
Bigdogca1966
Found those also.. The dealers believe it or not is cheaper....thanks for the post
Old Apr 13, 2016 | 11:01 PM
AllaboutMPG
Are you looking for round or oval shaped?
Engine Oil Temperature Sensor Pigtail 94-03 - Riffraff Diesel Performance
How much is the dealer getting for one?
Old Apr 16, 2016 | 10:15 AM
Bigdogca1966
It is round and I got it from the dealer..
Old Apr 19, 2016 | 01:21 PM
Bigdogca1966
Ok I was wondering if anyone had this happen. With the p0197 code the oil always registers the temp at 212 degrees since the pigtail is bad. When I start it runs rough like pulsing. Once it starts it runs great and the oil temp is always at 212. I figure once I can walk I will replace the sensor and this should take care of the problem. Anyone have this problem?
Old Apr 19, 2016 | 02:47 PM
retiredsparky's Avatar
retiredsparky
The PCM needs the oil temp information to decide how much fuel you need. Limp mode just like in cars with a bad air or water temp sensor. 7.3 with auto tranny uses the oil temp for this info. It is one of the more important sensors to the PCM.
Old Apr 19, 2016 | 08:08 PM
Bigdogca1966
I am hoping since I replaced the sensor and still get the p0197 code and the connector has exposed wiring that when I replace the connector and the part of the wiring that is exposed. That this code goes away and the PCM gets the correct info. I am going to do this tomorrow cross your fingers.. Hope it works for me
Old Apr 19, 2016 | 09:11 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Good luck!
Old Apr 24, 2016 | 10:23 AM
Bigdogca1966
Well let me tell you guys something.. I love my wife..I am laid up due to knee surgery and cannot get up there to fix this issue. So my wife all 5'2" of herself crawls into the engine compartment and does the job and did it great.. Checked to ensure the codes were gone and boom they were gone. She heat shrinked the connectors and made it look really good. My lil helper deserves a steak dinner tonight...
1bigjoe
Jan 25, 2010 07:32 PM
getnbz
Nov 2, 2007 09:59 AM
PSDmike
May 26, 2007 07:38 PM
njxlt
Jul 9, 2006 10:28 AM
sneak
May 12, 2006 04:09 PM
