thanks for the imfo.i got some wierd scanner numbers on the ipr.its building 2800psi at 35 % at 2200 rpm.falls flat on its face and starts to smoke and run rough. the thing starts and runs good until 2200rpm.any ideas? thanks
with out chip.we got 3 of these trucks for work and another 1 come in last night with same prob.now i got 2 trucks down.took 3rd truck out and drove run like a champ.so i switched idm no change.i guess its one of those days! is any way to test the ipr.thanks
just thought i would give you a update on what i found wrong.the first truck had a bad eot senser .the 2nd truck had the wrong ipr senser in.some other shop worked on this a while ago .amagin that.but anyway i got it to run pretty good. the o-rings are stating to leak but thats another day!thanks for all your help and good info on this site.thanks mod8
