EOT not reading right
Old Mar 24, 2015 | 08:12 PM
andy's2000's Avatar
andy's2000
2000 7.3 EOT read 272* with engine cold new Ford sensor only getting 3.95 volts at sensor plug and at the 42 pin connector from PCM should be 5 volts, dropping 1 Volt some where I disconnected all the sensors that share this voltage IAT,EBV,ICP,IPR,MAP no change. I left the EOT unplugged and the truck runs good I'll run it like this until someone can tell me was going on. Thanks for looking.
Old Mar 24, 2015 | 08:16 PM
white Buffalo's Avatar
white Buffalo
What are you using to read the EOT?
Old Mar 24, 2015 | 08:25 PM
andy's2000's Avatar
andy's2000
I'm using a VOM
Old Mar 24, 2015 | 08:36 PM
whitetmw's Avatar
whitetmw
Originally Posted by andy's2000
I'm using a VOM
KOEO, what is the voltage to the sensor, using the PCM Ground Circuit? And, what is the voltage at the PCM? Using the PCM Ground Circuit. Also, the Transmission uses this circuit. So, you could have resistance in that side as well.
PCM:
Pin#37 OR/BK is the PCM 5v Reference
Pin #25 PCM / Circuit Ground
Old Mar 24, 2015 | 08:37 PM
white Buffalo
just realized...............................Don't know VOM unless you meant volts on meter.
Old Mar 24, 2015 | 09:46 PM
andy's2000's Avatar
andy's2000
I'm getting 3.95 volts from EOT plug to battery ground same voltage from 42 pin connector pin 17 which I think is pin 38 at PCM. Thanks
Old Mar 24, 2015 | 09:51 PM
whitetmw's Avatar
whitetmw
I'm assuming its an automatic Trans?
What are you viewing the PID on? Scanner, gauge?
The purpose of checking at the PCM is to eliminate both the PCM and wiring as the fault.
You should be checking it at the PCM Ground for the most accurate reading. Just sayin...
The Speck on the EOT is "It should change from a higher voltage (2.6V) (this is the SIGNAL side) for a cold engine, to a lower voltage as the engine warms up (0.6V)" 210*F. The input voltage can be anything over 2.6V.
You may have a defective sensor. OR corrosion or bad connection at the sensor.
I would advise against driving the vehicle until you get it figured out. The EOT also controls other functions.
Old Mar 24, 2015 | 10:21 PM
white Buffalo
for comparison if this helps.................
Old Mar 24, 2015 | 10:28 PM
whitetmw's Avatar
whitetmw
Higher the voltage, lower the temperature. If he's stuck at 3.94 the sensor would be suspect followed by the wiring.
Also, just FYI there is app called Tiny Take by Mango which works great for capturing screen data. Does parts, whole screen, crops, many different formats, etc.
Old Mar 24, 2015 | 10:31 PM
white Buffalo
your on it like always Tom
Old Mar 24, 2015 | 10:32 PM
andy's2000's Avatar
andy's2000
I have manual trans. the sensor is new Ford product. thanks
Old Mar 25, 2015 | 07:45 AM
Jesser02EX's Avatar
Jesser02EX
*New* doesn't mean it isn't defective. What was wrong that made your change the sensor in the first place? Did the previous sensor show the same issue?
Old Mar 25, 2015 | 08:05 AM
Tugly's Avatar
Tugly
VOM - Volt/Ohm Meter. It sounds like the voltage is right on a cold truck, if cold is close to 55-65 degrees F.
I assume you did this without taking the 42-pin connector off. For those wondering, taking the connector off will open the circuit and you will not get sensor output voltages.
Old Mar 25, 2015 | 09:46 AM
andy's2000's Avatar
andy's2000
The stock sensor was reading high I replaced it with a sensor from auto parts store same high reading, replaced it with new Ford sensor same problem. I discovered the voltage to the sensor was only 3.95volts unplugged. Thanks
Old Mar 26, 2015 | 03:14 PM
whitetmw's Avatar
whitetmw
I checked two 7.3's today (actually showing someone how to do it and why to check at the PCM). You have either a bad new sensor OR incorrect sensor for your truck.
Both field circuits were 3.95/6v, 5.4v @ PCM.
