Things Not to Do In Your Garage...........
#361
well there was that one time with a VW bus where I was wiring up a heater blower to push heat to the front. Needed a spot for the ground, and thought that just a small hole and a sheetmetal screw would do fine. Except the sheetmetal was the bottom of the tank, which of course was full. Fortunately, just gas coming out, no explosion from the electric drill, but a few gallons on the floor of an attached garage can keep you in the dog house for a long time
#362
I had an engine fire in a VW bus...it got so hot in the engine compartment it blistered the paint on the licence plate hanging on the outside of the engine cover. Pulled the gas tank out (it sits above and in front of the engine, behind a bulkhead on later model buses) and the tank still had gas in it.
#364
One recommendation; one story. Although muriatic acid is a great concrete cleaner, DO NOT use it in the garage. Everything in there will rust solid! I know a guy that did that in his machine shop.
About a million years ago in HS shop class, we cut up an old Caddy that a guy wanted the engine out of. We scrapped the rest of it. We cut the whole thing up before anyone discovered the 1/2 full gas tank! Lucky class that day!
#365
#366
This is a do . . . treated lumber drops from decks or other outside projects are a pain because you can't burn them or toss them in the trash. So they just seem to collect in the various corners of your garage or shop. Take a few hours on a Saturday and make a set of what I call "body blocks". First I determined how far it was from my chest to the floor while on my creeper. Then I took all the sections of 2x12 & 2x8s that were laying around, cut them to equal lengths and nailed them together until the stacked height was the dimension I was looking for. Now whether the car is on stands or ramps, I slip a couple body blocks under the sub-frame and breathe a little easier while working. On a side note, the wife helped me determine how high to make the blocks. I think she volunteered just to catch me prone on the garage floor.
#367
Originally Posted by Beemer Nut
While rejetting a Holley placing a damp gas rag in your back pocket, "wow will that red rash burn". My best tig welding stunt was placing the hot filler rod in the mouth. In the garage doing motor sounds while passing gas,.....oops farts have lumps?
Doing a brake job and bending forward on your chair with Brake Klean in your lap, "***** Clean".
#368
Never do a tractor hydraulic oil change where you expect to catch 14 gallons of oil by "speed shifting" between 5 gallon buckets.
Never move 5 gallon buckets full of hydraulic quickly from one place to another.
Never work with full containers of oil in a confined space (eg: under a tractor or truck).
Never assume that a little oil spill in a garage can be cleaned up with a couple of paper towels or a rag.
Lou Braun
Lou Braun
#369
Trying to catch 20 gallons of coolant is another mater tho...
#370
Lou Braun
Lou Braun
oh yeah when doing the above make sure you have enough cans because putting the plug back in is near impossible.
all this was while working on an m981 all to change a fuel level sending unit.
#373
on
1 Post
No matter how big of a hurry you're in, how hot it is, or how short the cut is, Mr Plasma Cutter and Mr Short Pants should never be introduced.
Cut a trrack bar bracket off of mt friends XJ - took all of 20 seconds (once things were hooked up).
Took him about 10 minutes to get all the molten slag out of my ankle
His daughter still remembers all the words I taught her.......
#374
#375
