Offroad & 4x4
Flogged the Cap'n
Old Jan 9, 2006 | 12:56 AM
  #76
RubberDuck's Avatar
RubberDuck
10-4. I was hoping once you turned the diff, the tcase angle wouldn't be that bad. I would say run limit straps after you clearance the yoke just to be sure. Or a piece of chain works too. Deist safety has limit straps for less than $30. But yeah, Jess can hook you up fo sho! But it ain't cheap. If I had ANY high clearance cv's I'd send ya one. But those don't end up in my shaft pile too often.
RubberDuck
Old Jan 9, 2006 | 11:57 AM
  #77
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Originally Posted by ivanribic
Well no problems in particular Duck. Here's the deal: My pinion angle is 0º up front. The angle at the t-case is about 27º which is where the issue is. That CV is maxed out and if my driver's side tire drops at all there's binding in it. So my plan was to have High Angle build me a new shaft that could handle 27º no trouble. Jesse can do it, but it'll cost me better than $700. Eventually I'll do it but I can't afford it right now. My plan was to get the ol' grinder out and clearance the yokes a bit so I could run this shaft for now but I didn't get time before the bog. Surprisingly though, the shaft held up fine. When I head back down there at the end of the month I'll clearance the yokes and run that for the rest of the year or until I blow it up. Then I'm buying one from Jesse.
my front shaft has pretty much clearanced itself at the yoke...it used to bind with a little droop at the cv, but now it doesnt bind at all....i have one of jess's 1350 cv shafts to throw in it, im just saving for the 1350 yoke and the cv flange
Old Jan 9, 2006 | 12:40 PM
  #78
ivanribic's Avatar
ivanribic
Normally Jesse's stuff isn't so stupid expensive but apparently the trouble with my setup is that the married 205 with the C6 tranny has special clearance issues. The normal heavy duty CV that he would use won't clear the tranny which means he has to build some pretty fancy stuff to still be short enough to clear the tranny and yet handle the angle and power. If I'd have known all this a long time back I would have went to a divorced t-case from the beginning. This would have saved me from the knuckle turning job and all this mess with the front shaft, plus it would make pulling the tranny a lot easier. But you learn as you go I guess. I had never anticipated the truck becoming such a giant mud *****. It was supposed to be a mall crawler I tell you!!!!!
Old Jan 9, 2006 | 06:21 PM
  #79
KubotaOrange76
haha..i dont know if i got a good deal on mine or not, i picked it up for 200 bucks, and on the pinion end it has a brand new tom woods super joint thing installed...the joint with the funky trunion to give extra angle....it only has mild trail miles on it
I think its a decent deal...
Old Jan 10, 2006 | 11:37 AM
  #80
s8whiskey's Avatar
s8whiskey
That makes my head hurt with the happy. Very mean very sick. Just need one thing...More of the video. To bad it was lost its life I suppose.
Old Jan 10, 2006 | 12:25 PM
  #81
Russ T. Trombone's Avatar
Russ T. Trombone
Awesome vid Glad to see that the axles and motor held together. It woulda sucked to have blown the motor in the tank trap...or even on the way home!
Old Jan 10, 2006 | 02:22 PM
  #82
ivanribic's Avatar
ivanribic
Nah, my motor is fairly stout. The only way that would have happened is if I ran it completely out of oil.
Old Jan 10, 2006 | 02:28 PM
  #83
monsterbaby's Avatar
monsterbaby
Yeah but it would have been a great excuse to break out hte credit cards and start building a REAL engine.
<a href='http://www.smileycentral.com/?partner=ZSzeb008_ZNxdm824BXUS' target='_blank'><img src='http://smileys.smileycentral.com/cat/15/15_4_127.gif' alt='Voodoo' border=0></a>
Old Jan 10, 2006 | 02:54 PM
  #84
s8whiskey's Avatar
s8whiskey
A real engine? What would you say he replaces that incredible sexy 460 with?
Old Jan 10, 2006 | 03:14 PM
  #85
proeliator's Avatar
proeliator
Any motor with less than 500 cid is for wussies
Old Jan 10, 2006 | 03:22 PM
  #86
ivanribic's Avatar
ivanribic
It's either gonna be a 545 or a 557 depending on what my block will let me do. I'll probably find out this week or next.
Old Jan 10, 2006 | 03:24 PM
  #87
proeliator's Avatar
proeliator
*cough* IDT *cough*
Old Jan 10, 2006 | 03:32 PM
  #88
1970Custom's Avatar
1970Custom
Why not just shoot for 600 cu in??
Old Jan 10, 2006 | 03:33 PM
  #89
monsterbaby
Well this might work
Old Jan 10, 2006 | 03:49 PM
  #90
proeliator's Avatar
proeliator
Fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap flhyple fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap fhap......................and I'm spent
I'm typically not envious of other guys' builds, but I'd totally frame and hang that pic in my shop for inspiration...Skipped should be proud!
