I'm Gunner15a, and I'm from a little west of Springfield, in a town called Billings (here pretty soon, anyway) I have an 06 4x4 F250 PSD Extended cab and an 03 F150 XLT Extended cab.
Ok I'm checked in now
Hey Gunner15a, I go to Rogersville, MO (15 Miles east of Springfield) on Friday nights for Ozark International Raceways Test N' Tune. You should come by and watch, or better yet, even participate in the drags!! Cost $8 to get in as an observer or $10 for the vehicle and driver. Too fun!!
Might do just that...........if this job doesn't run me into the ground
Welcome to the Missouri chapter jlallred. I took care of your join request and you're a member of the Missouri chapter now. Where in Imperial do you live? I'm off the outer road on Miller.
I am over off old 21 and West Rock Creek. Not too far from you. I come accross Rock Creek to Old Lemay Ferry all the time to friend's house off Miller, and an occasional stop at the Elks for a beverage.
I have a post going on the pre-powerstroke forum and the 93 range of trucks. I currently have two problems: a brake line just rusted through over the left rear axle, and I have an issue with the clutch not disengaging all the way. The clutch issue may be related to play in the hole of the bracket that the cross arm goes through. It moves away from the firewall when pressure is applied to the clutch peddle, this may be just enough to not fully actuate the master cylinder.
