Tranny cooler - which one?
Old Dec 1, 2005 | 09:51 AM
skibender's Avatar
skibender
I'm looking at putting on an addition tranny cooler. What brand do you guys recommend?
Old Dec 1, 2005 | 03:14 PM
nlemerise's Avatar
nlemerise
I put in a Tru-Cool (#40K model) and transmission temps dropped signifigantly...easy install too . While I was at it, I installed an external transmission filter with a valve to drain transmission and replace fluid easily. The easier it is to do, the more likely I am to do it!
Old Dec 1, 2005 | 03:15 PM
clintbonnie's Avatar
clintbonnie
One of the better cooler on the market that alot of PSD people use is the "Tru Cool LPD" cooler.. i have one and it does the job.. i am using the 28,000 rated unit..if you pull or haul anything heavy, i would suggest this one.. along with a trans temp gauge and keep the temps under 220 degress. see the following website for more info.. http://www.tsscoolers.com/
Old Dec 1, 2005 | 04:38 PM
edub32's Avatar
edub32
If you don't want to spend a lot of money you can use other Ford tranny coolers. You can use the V10 one which is bigger than the 7.3's or the 6.0 one which is bigger than all three.
Old Dec 2, 2005 | 06:49 AM
skibender's Avatar
skibender
Thanks for all the good info. Does the Tru-cool kit come with the proper fittings? Do I need to get any other hardware before the install?
Old Dec 2, 2005 | 06:56 AM
nlemerise's Avatar
nlemerise
If you go to dieselsite.com they will provide you with everything you need...all fittings included.
Old Dec 2, 2005 | 09:46 AM
skibender's Avatar
skibender
Does the PSD have the 1/2" fittings?
Old Dec 2, 2005 | 06:16 PM
johnny8's Avatar
johnny8
[QUOTE=clintbonnie]One of the better cooler on the market that alot of PSD people use is the "Tru Cool LPD" cooler.. i have one and it does the job.. i am using the 28,000 rated unit..if you pull or haul anything heavy, i would suggest this one.. along with a trans temp gauge and keep the temps under 220 degress. see the following website for more info.. http://www.tsscoolers.com/[/QUOTE]
i second this information, with one revision... i would say try to keep your tranny temps to 200 degrees or less... i'm sure your tranny would survive running at 220, but if you are running that high, you should have put a bigger cooler on...
Old Dec 5, 2005 | 06:24 AM
skibender's Avatar
skibender
Thanks again for all the help. I ordered the Tru-Cool and Sonnax from Black Cloud.
Sailor182
Jan 7, 2012 10:49 PM
BigWhite94
56
Jul 21, 2010 08:56 PM
PSNut
41
Jun 23, 2006 11:04 PM
roosplash
Feb 11, 2006 12:58 PM
bdh
Jul 1, 2002 01:39 PM
