Tranny cooler upgrade
Old Jun 30, 2010 | 07:03 PM
BigWhite94's Avatar
BigWhite94
I want to get a bigger Transmission cooler, and was wondering if it would be better to get the Tru-Cool tranny cooler to add, or can the V10 style trans. cooler be fab'd to work on the OBS?
Old Jun 30, 2010 | 08:42 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Both are very similar, I have the Tru-cool and very happy with tranny temps. Get rid the stock cooler, its crap. If you want go more get a 6.0 tranny cooler.
Old Jun 30, 2010 | 08:58 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Here are some pics, to get the idea: the first one with the stock of a SD (the smaller) against the 6.0l (the bigger) and the second the tru-cool MAX (like mine).
Old Jun 30, 2010 | 10:55 PM
BigWhite94's Avatar
BigWhite94
Wow the 6.0 is that much bigger? I like the look (and the price) of the Tru-cool. I think I will probably go that route.
Old Jul 1, 2010 | 11:26 AM
Brown Falcon's Avatar
Brown Falcon
Tru-cool is good stuff
Old Jul 1, 2010 | 11:28 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
You probably didn't get the thermal bypass did you? also did everything come with the kit or did you have to buy extra part or make brackets?
Old Jul 1, 2010 | 12:16 PM
427 fordman's Avatar
427 fordman
I put the thermal bypass on mine. The only thing extra I had to buy was some 5/16 rubber trans line. Kit comes with 3/8 fittings, truck has 5/16 steel line. The 5/16 rubber line fits over the 3/8 fittings so that's what I did. Some have changed the steel lines on the truck to 3/8. I don't know how much u gain by that besides having the sizes match up correctly. Worked just fine this way, I'm not the only one who did it like this.
Old Jul 1, 2010 | 01:18 PM
Action4478's Avatar
Action4478
Check With Racer X...here,,,,
Old Jul 1, 2010 | 03:14 PM
redone1's Avatar
redone1
I'm another that jumped on the Tru-cool band wagan and very happy that i did (tranny is even happier). Dropped my pulling temps by around 50 degrees.
Our stock cooler is horrible in my opinion.
Old Jul 1, 2010 | 03:21 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
No I didnt get the thermal bypass, I dont needed it here in my country. And everything came with the kit, I just mod the stock brackets and made some new ones, and thats it.
Old Jul 1, 2010 | 11:40 PM
cowmilker08's Avatar
cowmilker08
Could someone post a picture of the stock cooler on the OBS trucks?
I was told when I bought my truck that it had and aftermarket cooler but IDK.
Old Jul 1, 2010 | 11:52 PM
fordpride's Avatar
fordpride
This is the OEM replacment that autozone sales
Old Jul 1, 2010 | 11:58 PM
kawa's Avatar
kawa
Talking
The advantage of upgrading the 5/16" lines to 3/8" is that you appreciatively move a larger amount of fluid through the larger upgraded cooler and return more cooler fluid to the tranny thus making for a happier tranny and extending it's life.
I spoke with our tranny guru, Mark K. prior to upgrading mine and he indicated that the larger line upgrade was a worth while mod.
Rog
Old Jul 2, 2010 | 06:03 AM
427 fordman
Nice, thanks Rog. I'll check out my temps this summer pulling and make the decision then if I want to switch the steel lines.
Old Jul 2, 2010 | 07:26 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Just regular steel brake line isn't it?
