Cluth Problems
Old Oct 23, 2005 | 08:01 AM
Melungeon1's Avatar
Melungeon1
Cluth Problems
I have an 85 F250 with 4.9l 300 six. I have just put a new clutch ,pressure plate, throw-out bearing, and had the flywheel turned. Upon trying it out i noticed the clutch would not fully disengage. I have adjusted everything there is and some there’s not…lol.
i have bled the system with no results. i have checked my receipts and found that all the parts used were the correct ones. I NEED HELP. it seems as thought there is just a hair more pedal needed. it will drive and i can force it into a gear with a synchronizer, but reverse and bulldog are a challenge. do you think they took to much off the flywheel? I’ve also heard about a cracked fire wall that allows flex? i even but a threaded bolt in the salve and adjusted it until the clutch would slip without any pedal depression. when I depressed it no change. Its like I’m on the bottom and nowhere else to go? it has to be a wrong part?
HELP
Old Oct 23, 2005 | 08:08 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 23, 2005 | 08:19 AM
holland501's Avatar
holland501
There are some threads about a problem with some plastic sleeve on the clutch but I have no personal experience with it. I do have a couple of ideas though. Did you compare the old parts with the new before installing? Parts have been boxed wrong before. Remember that most parts come from out of the country. The folks in that country probably can't read english. Chances are they can't read at all. Now here's the killer. Is it posible you installed the disc backwards? It happens a lot. Good luck.
Old Oct 23, 2005 | 08:53 AM
Melungeon1's Avatar
Melungeon1
No i didnt do a direct comparison... my mechanic said they were the correct parts. i bought them from ford. they checked them against my vin number
Old Oct 23, 2005 | 08:57 AM
texans's Avatar
texans
that is what I was going to say. When I did my first clutch (when I was 16) I put the disc bassakwords. it wouldnt bleed, and I had to pump the clutch mutilple times to shift. I did that for about a week before I took it back apart and found out it was in wrong. GL
Scotty
Old Oct 23, 2005 | 08:59 AM
texans's Avatar
texans
oh and welcome to FTE this is a great site. Im sure you will find all the help you will need. once again good luck
Old Oct 23, 2005 | 09:02 AM
Melungeon1's Avatar
Melungeon1
ok i guees i will have to check
Old Oct 23, 2005 | 09:05 AM
Melungeon1's Avatar
Melungeon1
when i bled the clutch it just went to the floor...i had to manual pull it back up and pump till it came back...even then it was the same not fully diengaging
Old Oct 23, 2005 | 09:08 AM
texans's Avatar
texans
yeah sounds like the same thing I ran into when I put the dics in wrong. I would check that if I was you. GL
Old Oct 23, 2005 | 10:51 AM
Lee Lichterman's Avatar
Lee Lichterman
I don't have much experience with this problem but a few things I recall reading here that also might be it.....
Any chance carpet is too thick preventing peddle from going all the way down? SOme people add sound material or replace carpet, put in a thick mat etc that takes away a 1/4 inch or so of pedal movement. When I first bought my truck, the guy had a mat in it that would catch the gas pedal. No excitement like trying to stop and realizing your gas pedal is stuck down!!!
Also, there was a problem with firewall flex on these right at the clutch that prevented proper clutch engagement. They even build a kit to correct it.
If you can't find something simple like putting it in wrong or carpet, I would bet it is a flexing firewall.
Good Luck,
Lee
Old Oct 23, 2005 | 06:35 PM
plowpusher's Avatar
plowpusher
i ran into the same problem on a 85 you can reindex the bellcrank you take he linkage apart under the dash rotate it and bolt it back on it was a PIA but it worked
99F350dually4x4
Jun 30, 2011 10:08 PM
fordopie
1983 - 2012 Ranger & B-Series
Oct 11, 2009 09:20 AM
JR270
Jan 3, 2005 08:40 AM
DrkPhanstm
Apr 29, 2002 01:24 AM
shadetree wrench
May 20, 2000 07:55 AM
