torque converter
Old May 13, 2002 | 09:17 PM
rok ford's Avatar
rok ford
torque converter
Need help.Before dropping the c-6 in my 79 f150,I drained the torque converter.Now its time to put it back in and of course I didnt pay attention to how much fluid drained out.I need to know the capacity.I cant find this info in any manuels.Thanks.
Old May 13, 2002 | 09:38 PM
firerod1's Avatar
firerod1
torque converter
usually you can try to put about a quart in it,but when you go to put it on the trans be quick cause it will try to pour out.If you can't don't sweat it because the fluid is circulated through the trans and the tc and will fill on it's own once you start your truck(and the pump starts circulating fluid through your trans.Make sure to fill your trans with fluid(you should be able to get the # of quarts from your manual),start the truck,cycle through the positions(p-r-n-d-2-1)and back to park, then check the fluid level w/ the truck running and add as necessary(cycle through positions each time and be careful not to overfill as this can cause foaming and seal damage).good luck and tell me how it goes. Also,I have a 1979 f150 4wd I'm putting a 429 in.Anyone got a recommendation on a torque converter/ rebuild kit for my c-6?
Old May 13, 2002 | 09:53 PM
rok ford's Avatar
rok ford
torque converter
Thanks firerod1.I hope to get in next week.
Old May 13, 2002 | 11:53 PM
Mil1ion's Avatar
Mil1ion
torque converter
hav24wheel
Mar 6, 2013 01:44 AM
Mustangoutcast
Jan 15, 2008 12:06 PM
rmilchman
May 17, 2006 08:56 AM
MJW
Mar 10, 2004 07:15 AM
HIGH_N_DRY
1978 - 1996 Big Bronco
Nov 3, 2002 10:06 AM
