Trans drain and fill??
Old Feb 27, 2013 | 03:40 PM
hav24wheel's Avatar
hav24wheel
If I do a drain and fill, is there a plug on the torque converter like on the older Fords??
Old Feb 27, 2013 | 03:47 PM
Stewart_H's Avatar
Stewart_H
I can't remember when Ford stopped putting a plug on the TC, but I'm pretty sure your '03 doesn't have one.
If your looking to do a complete flush and refill, you know about Mark K's write-up, right?
https://www.ford-trucks.com/article/...nsmission.html
Stewart
Old Feb 27, 2013 | 04:01 PM
hav24wheel's Avatar
hav24wheel
Ya, I ready the write up already. But I was going to change to Royal Purple, and wanted to drain everything, blow out the cooler and put a new filter in the pan, and add a external filter.
I was really hoping there was a drain.
Old Feb 27, 2013 | 05:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The last torque converter drain plug was installed in August, 2001.
The procedure referenced above will change more fluid than if you could drain the pan, torque converter, and blew out the lines. Why don't you want to use it?
Old Feb 27, 2013 | 05:56 PM
hav24wheel's Avatar
hav24wheel
I thought it would take a lot more fluid that way to change it over to as close to 100% as I could get.
As of now it has 109,000 miles on it, and as far as I know it's never been changed. I figured I'd put full synthetic in it to make the trans last longer.
So your sayin, with the flush method described, I'd be better off anyways?
Figure 5 gallons is enough?
Old Feb 27, 2013 | 08:01 PM
Mark Kovalsky
I recommend reading the whole procedure before starting. It calls for 20 quarts, or 5 gallons.
Old Feb 27, 2013 | 08:06 PM
hav24wheel's Avatar
hav24wheel
I'll have to reread it again, it's been a wile.
I was just thinking might take a bit more when flushing with the same oil that's in there vs changing the type to get a total change due to some old oil staying behind b
Old Feb 27, 2013 | 09:19 PM
Mark Kovalsky
No, it does not.
Old Feb 28, 2013 | 05:48 AM
sammie0126's Avatar
sammie0126
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Stewart
On my 2000 I have a TC drain but if you use Mark's procedure for the complete flush using the return lines you don't need it, I flushed mine using his write up and never pulled that plug, just the pan, change filter, replace, open lines and flush. Used 19 and 1/2 quarts of fluid and got a transmission facial and shower to boot!
Old Feb 28, 2013 | 06:43 AM
hav24wheel's Avatar
hav24wheel
I'm going to do the same as you, but - the facial n shower part........... Hopefully. Lol
Old Feb 28, 2013 | 07:23 AM
Archion's Avatar
Archion
Veteran: Marine Corps
That was 6 letters/ 1 contraction away from one of the most hilarious things I have evar read on these forums... But then again people say I'm twisted anyway...
Old Feb 28, 2013 | 12:25 PM
az_r2d1's Avatar
az_r2d1
C'mon, gives us the full story. How did it happen?
I need to do this too. Just not looking forward to spending 200 bucks on mobile-1 synth mercon-V....
Old Feb 28, 2013 | 03:32 PM
sammie0126's Avatar
sammie0126
Well no one told me (until after) that the filter was going to still be full of fluid even after sitting for an hour. Pulled it out and got a face full. Then got the shower with the return line because the bolt had some rust and got it out about 4 turns and it got stuck. Took 19 quarts out but only 17 went in the bucket the rest went on me and the garage floor. In fact the clothes I had on that day were thrown in the trash and took about 6 attempts to get the fluid out of my hair. But will take nasty tranny fluid anyday over gear oil so that's the good side of the story -at least it wasn't gear oil.
Old Feb 28, 2013 | 05:18 PM
EXv10's Avatar
EXv10
So you can imagine what it was like for me when I r&r'd auto trans as a job when I was a kid. Funny thing is; we never paid attention to which way the drives-shafts went back in which leads me to believe that was another myth. Now it's; "oh, don't forget to mark it!".
Old Feb 28, 2013 | 05:26 PM
hav24wheel's Avatar
hav24wheel
That is a myth. The shafts are balanced off the vehicle, so it doesn't matter what way they go.
