transfer case without a low range?
Old May 13, 2002 | 09:01 AM
2Wise4aGM's Avatar
2Wise4aGM
Hey guys. I'm looking at buying a 76 f100 4X4 360 with a 4 speed. The tranfer case only has 2wd and 4wd. Are these common? It looks to be gear driven with a cast iron case. Thanks
ONLY LITTLE BOYS WEAR BOW TIES
Old May 13, 2002 | 01:54 PM
79f3504x4's Avatar
79f3504x4
I think early to mid 60s used a tcase with no low range.Might be an older case out of another truck.Brian
Old May 13, 2002 | 03:43 PM
zahn20's Avatar
zahn20
I had a 76 F100 with the same t-case and a 4 speed as well. I don't know if it was origional or not because the truck had a 428 in it replacing the 351M.
Old May 13, 2002 | 05:45 PM
blaxuede's Avatar
blaxuede
I have a Dana 21 t-case in my truck, it's also only 2wd and 4wd. Maybe you have the same thing.
Old May 13, 2002 | 09:00 PM
Jermafenser's Avatar
Jermafenser
You probably saw a single speed (Dana 21) transfer case. Very simple setup.
Old May 14, 2002 | 12:44 AM
db4476's Avatar
db4476
The '76 that owns me is the same. It's a Dana 21 and works great with the transmission that has granny gear.
Old May 14, 2002 | 02:53 AM
Torque1st's Avatar
Torque1st
Posting Legend
mtullis
May 10, 2013 10:28 PM
fords17
Jun 15, 2011 09:11 AM
lisagoud
Sep 27, 2009 09:58 PM
