Sponsored by: Real Truck
How do I drain torque converter
Old May 14, 2006 | 07:50 AM
rmilchman's Avatar
rmilchman
I have an '02. I changed the tranny fluid last year, but didn't drain the converter, I want to put synth in so need to do a total drain.
Thanks
Old May 14, 2006 | 08:08 AM
billbain's Avatar
billbain
There is a good writeup in this site somewhere on how to go about a complete fluid change. It is a simple operation and worked very well, do a search on fluid change.
Old May 14, 2006 | 08:19 AM
Casey's Avatar
Casey
It's here:
CLICK ME!
Old May 14, 2006 | 06:19 PM
rmilchman's Avatar
rmilchman
So I don't have to pull the drain plug on the panb? I can pump the pan and the torque converter dry?
Old May 15, 2006 | 07:27 AM
Casey's Avatar
Casey
You can pump the pan dry, and pump out the old fluid from the converter while replacing it with new fluid. There is no way to pump the torque converter dry.
If your '02 was one of the early ones it may have a drain plug in the torque converter. Ford stopped installing drain plugs in August, 2001.
Old May 15, 2006 | 07:55 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Are you sure about that?
Denny
Old May 15, 2006 | 08:21 AM
rmilchman's Avatar
rmilchman
If I remember my truck was built Feb '02. Since the reccomended tranny fluid is no longer readily available I was going to go with synth, but wanted to get all the old out. I would think that if I can not drain the torque converter I will be left with a blend instead of synth.
Old May 15, 2006 | 09:27 AM
Casey's Avatar
Casey
Yes, I am. No more torque converter drain plugs after August, 2001 built torque converters.
Old May 15, 2006 | 09:30 AM
Casey's Avatar
Casey
If you use THIS METHOD you will get about 95% of the old fluid out.
Old May 15, 2006 | 09:36 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Depending on your mechanical skills and willingness to be elbow deep in ATF, you might want to just bring it somewhere to have it changed
Old May 15, 2006 | 12:12 PM
rmilchman's Avatar
rmilchman
If it's as simple as disconnecting a pipe, and feeding it into a 5 gallon pail, how bad can it be. I already did the sonnex valve, and yest that was a mess.
Old May 15, 2006 | 01:12 PM
krewat's Avatar
krewat
I've never done an ATF change, even with all the hose I want, where I didn't get SOME of it on me
Just try disconnecting a tranny line and see what flows out
I'm being somewhat sarcastic, but having someone do it for you is certainly an option. I do everything myself, it's not an option for me
Old May 15, 2006 | 01:53 PM
rmilchman's Avatar
rmilchman
I'm too cheap to pay someone for simple stuff. Maybe I'll get one of my kids to hold the line, they seem to like to get messy.
Old May 15, 2006 | 02:19 PM
krewat's Avatar
krewat
I KNEW there was a use for these kids...
Old May 17, 2006 | 08:56 AM
rmilchman's Avatar
rmilchman
I was thinking about it and wonder if this would work, basically the same way I did my 50 gallon water heater. Connect an air compressor to the tranny where the return line is diconnect and let the air flow the fluid out.
V10man
Jun 2, 2013 04:55 PM
blowhole
Jul 9, 2010 07:34 PM
cecilt
30
Feb 18, 2010 09:09 AM
05ExcursionLTD
Jun 19, 2009 07:15 AM
ispurlock2000
Aug 6, 2007 06:01 PM
