1978 - 1996 Big Bronco
Torque Converter Drain
Old Oct 27, 2002 | 10:38 AM
HIGH_N_DRY's Avatar
HIGH_N_DRY
Is there a Torque Converter Drain on the 95 E4OD?
Old Oct 27, 2002 | 01:52 PM
greystreak92's Avatar
greystreak92
To the best of my knowledge, yes there should be. Removing the rubber plug in the bottom of the bell housing should allow you access to the plug in the converter. My '92 has a square head plug. You may ned to tap the key or rotate the converter by hand til it lines up with the hole in the bell housing.
Old Oct 27, 2002 | 11:16 PM
jad's Avatar
jad
I just changed my tranny fluid/filter tonight and i have the plug
94' 351 with e4od
Old Oct 28, 2002 | 05:02 AM
HIGH_N_DRY's Avatar
HIGH_N_DRY
Thank you Greystreak, I was lookin behind the inspection plate.
Much Obliged, Paul
Old Oct 28, 2002 | 11:08 AM
cwade3's Avatar
cwade3
I,m considering draining my converter also its a 95 bronco with e40d and was wonder if the converter is drained how much extra fluid do you have to add to the tranny and will it fill up if it is added thru the tranny, new to fords so im not sure and my haynes doesnt say how its added back to the converter most ive seen is the converter has to be pulled thanks for any help?
Old Oct 28, 2002 | 11:19 AM
adelyser's Avatar
adelyser
[updated:LAST EDITED ON 28-Oct-02 AT 12:19 PM (EST)]If you drain the pan and the torque converter, you will need between 16 and 17 quarts of fluid. Both of mine took right at 16 quarts.
Old Oct 28, 2002 | 11:45 AM
cwade3's Avatar
cwade3
Aaron d thanks again for the info you have given me lots of good tips since ive started on this site grasious! sounds like to me you have just about rebuilt your ride. I dont know what i would have done with out this site and people like yourself to help others, keep up the good job.
Old Nov 1, 2002 | 07:08 PM
cwade3's Avatar
cwade3
hope you respond by this weekend 2,3 nov still didnt answere if it could be added straight to the trans or did you have to pull the converter? sorry for being ignorant, never tried this. always owned a chevy before and had to pull the converter. thanks for any info.
Old Nov 2, 2002 | 01:19 PM
Torky's Avatar
Torky
The trans pump refills the TC on its own. Just add ATF to the dipstick tube. When about 1/3 to 1/2 of the total amount is added, start it and run it in PARK only, for about half a minute. Then shut it down and add the rest.
Old Nov 3, 2002 | 08:03 AM
cwade3's Avatar
cwade3
thanks for the info torky. this is a great site.
Old Nov 3, 2002 | 10:06 AM
DeGideo's Avatar
DeGideo
Coastal68
Jun 29, 2016 11:07 PM
maytea
13
Sep 26, 2015 02:09 PM
makthenif
Dec 28, 2010 06:02 PM
05ExcursionLTD
Jun 19, 2009 07:15 AM
omni
Jul 1, 2004 12:56 AM
