Group Tech Article Input - Welding
So am I going to have a problem? What is the problem?
I understand hi-carbon steel is harder to weld - but if it is working for you then I would be tempted to continue. It is still steel, and your tach welds are holding.
I expect they recomend glue to avoid overheating and stretching the joint.
Wish I could give you a better answer - it is just that not very many of us have any experance with the new stuff.
Any tips on welding sheet medal I should know about? Voltage? Wire speed?
Equipment I'm using - Miller 135 mig and 023 wire.
Thanks for the help.
Dffay, thanks for the information on the type of steel - is the same steel used in all cars, or do different companies use different mixes?
"Body panels are HSS High Strength Steel that also has galvanizing and some proprietary alloy composition so it won't weld well,"
Most "silver" solders contain little to no silver but are an allow of nickle, copper, and other metals, basically a white colored brass with the same problems as yellow brass.
It is low temp so warping is not too much of a problem if you are careful about heat application.
Would it be different on the newer metals?
What kind of glues are we talking about? Is it something special?
Ok the welding was no problem, though I did get some warping. Didn't really have a lot of heat, think it was caused more my shrinkage. Was able to fix some of it as a ment by hammering but wasn't really sure if I has hammering correctly, I used a metal block behind the weld and hammered on the front of the weld.
The guys here are really impressed they think it looks great, better than they could do, but thats all because I took my time and got some good information on how to do it correctly.
I guess I'm a bit dissapointed with the warping, a little fill will clean it up but I was hoping for better, perhaps I will try and glue the the other side. This way I've tried both.
But again I have to say the beads are really nice, if not for the warping. Oh well for my first time I guess its ok. Looks better than the rust holes that were there.
Thank guys for the advice and sorry for highjacking your forum with this newer stuff.. LOL
I found that it is indeed a problem to the darksiders, and those who wish to repair the newer trucks. While you need a degree in advanced molecular chemistry to understand it all, basically the formula for steel has changed. Worse, many different formulas are used - even different in different parts of the same vehicle.
Each formula has different welding and working characteristics - and some may be damaged by the heat of welding. I guess this makes sense as the manufacture's are recommending parts be glued together rather than welded.
I have long intended to scab the rear tail light assembly and tailgate from a '87 ford onto my '59, now I will have to reconsider just how to do this. I would not want to be going down the road and have my rear sheetmetal fall off.
I wrote a page up on what I found, and will include it as a sidebar in the article. I have posted that page on my website, please read it and post any corrections/questions/additions you may have.
http://www.old-fords.com/New%20Steel.htm
Thanks
I'd suggest buying a copy of Ron Covell's Video www.covell.biz called "Basic Techniques for Working with Steel". It IMHO is the very best 40.00 you can spend. If for nothing else than to hear and see his demonstration/explanation of ON Dolly and OFF Dolly hammering and how each is used in straightening sheet metal, that alone can save you 40.00 in Bondo!
My best technique with any of them was to use my Mig, and spot each patched piece to an entire bead, then grind it off. ALways going opposite of the last spot and letting things cool inbetween. When done, grind it smooth and go on.
Some can do it with no filler, but bottom line is, and should be known, filler is not a bad word. Heck, after watching the show's on TV (AHR/Overhaulin, etc) the only way they get that "pristine" panel is after filler. Even the cars that win the riddler award, and the cars that sit at the top of the semi shows, all have filler on them..as evidenced by the "docu-drame-build" they show us.
I think sometimes folks get too hung up on a "perfect" patch and may get discouraged if they have to fill it, but geez, I've found sooo much lead in older panels that I am pretty sure were from factory jobs, I don't see an issue with cleaning things up with plastic filler. Only difference with using Bondo is it's cheaper, quicker, takes less talent and isn't as harmful to my health
