Group Tech Article Input - Welding
Old Mar 12, 2006 | 12:14 PM
  #151
bossind's Avatar
bossind
Originally Posted by WillyB
The suggested way is to fit the two panels together just like you were going to butt weld them. You then add a 2" strip of metal behind the joint, and glue each panel to it.
You use screws or rivets to hold the panels in place while the glue is drying. Once dry you grind the heads off the screws. Where needed you can also us countersunk rivets and leave them in place - just fill over them.
I have both an air operated and a hand flange making tool that bends a lip on one panel such that it slides behind the second. I have never used flanges for any joint, but will be trying that when the time comes.
Now thats a thought! I might give that a try! Thanks bud.
Old Mar 12, 2006 | 01:51 PM
  #152
WillyB's Avatar
WillyB
Irondragon used adhesives to replace the back of the cab on his 52 - check out http://www.old-fords.com/welding/glue.htm towards the bottom of the page.
If asked, use "fte" as a user name, and "weld" as a password.
Old Mar 13, 2006 | 05:31 PM
  #153
3Mike6's Avatar
3Mike6
Well, it's time for me to spill the beans, WillyB came by and we did a practice run on some 1/4in plate I had cut out (didn't have any frame).
Let me start by saying I have rarely done bottom up welds...
Here's what we did, I had three pieces of 1/4 inch cut to 2 1/2 x 6 inches.
Laid them together, sort of overlapping them with a gap left in the middle about 1 inch. WillyB will have pics which may make it easier to visulaize..
Anyway I went top down on one side (nice looking weld) and bottom up on the other (ugly looking weld). If fact i didn't think the bottom up was good enough so I made another pass bottom up, (ugly too BTW)
And then laid it in the press. After two or three pumps my pretty top down weld started to come loose....
Damn, We pressed it back flat and I ran another top down on it and put it in the press.
Held better, but still, the top down began to peel out of the metal....no issues at all with the bottom up weld.
Did I mention the bottom up was an ugly weld too? Also one I rarely do, if ever?
So, those of you who have said correctly that bottom up was stronger are right.
The welding was done on my Miller Vintage with .035 wire, 75/25 mix.
Only bummer about the whole thing (other than me being wrong ofcourse) is we ran out of wire when WillyB was welding so he didn't get to have a good feel for the Mig...kind of embarrasing on my part..
Soo, no more top downs for me in my future.
Old Mar 13, 2006 | 05:48 PM
  #154
AXracer's Avatar
AXracer
Question: by chance did you have the torch tip pointed up on both welds? "Pushing" the weld (pointing the torch tip in the direction of travel) will typically produce a more ragged looking but stronger weld, "Dragging" the weld may look prettier but won't get the penetration and is more likely to not center the bead over the seam.
Old Mar 13, 2006 | 05:57 PM
  #155
3Mike6's Avatar
3Mike6
Yes,
Tip was pointed up on both, in effect pushing for bottom up, I never considered trying to point the gun down on top-down.
Old Mar 13, 2006 | 08:49 PM
  #156
WillyB's Avatar
WillyB
Can't add anything to what Mike said, but here are the pictures.
First is of the materials - we layed them flat and tacked them, then welded verticle.
Second is the test jig and third is the completed welds. The nice looking weld is the one he did going down from the top. I thought it was the best weld and worried that we would get a bad test because to bottom up weld was not nearly as good.
Old Mar 13, 2006 | 08:54 PM
  #157
WillyB's Avatar
WillyB
The forth is a pic of his welder (one of two he had, plus a plasma cutter, plus a stick welder, plus a nice 36 ford, a 48 ford, a 39 dodge, and two more great bowtie projects!)
and the fifth is just to show that I did not do the welding.
Old Mar 13, 2006 | 08:56 PM
  #158
WillyB's Avatar
WillyB
And, as he stated, the results. Don't you just hate it when you prove someone else is right and you are wrong?
Old Mar 14, 2006 | 08:50 AM
  #159
Randy Jack's Avatar
Randy Jack
Way cool, guys! Will this test make the welding article?
Old Mar 14, 2006 | 09:48 AM
  #160
WillyB's Avatar
WillyB
Yes, as a sidebar on welding techniques. To me it is just as important to show how to jump in and weld something, and then test your welding, as is the telling of the best way to weld.
I am a beginner and learned a few things yesterday myself. For one thing I have been running my wire feed too fast, and (of course) need a bigger machine.
I also was able to see how the motion of the tip makes for a different weld. While I am not saying I am ready to weld on a frame, I will say that for the first time I can see myself doing so. I'll need a whole lot more practice, but welding is not black magic.
It also helps to know someone able and willing to coach you.
Old Mar 14, 2006 | 10:35 AM
  #161
3Mike6's Avatar
3Mike6
I'm going pick up some more wire this week and do the test again, but this time I'll butt weld then, instead of lapping them. I don't know why we didn't do it that way yestreday...in my mind I was trying to mimc something like welding in an IFS where the plates would be lapped over the frame rail.
Also, not sure where my head was at, but I had about a 6 foot piece of 3/16th laying on the floor next to all that box tubing.
And also I need to aplogize for being a poor host, I didn't realize it until I was talking to my wife later that evening, she said "he drove all the way from Madera and you didn't even invite him in for a coke?"
I got wrapped up in showing the various "junk piles of treasure" and it didn't click you had a 1.5 hour drive back home.
Even though we didn't get as much done as we wanted, it sure beat the heck out of sitting in the office on a Monday afternoon!
Old Mar 14, 2006 | 10:37 AM
  #162
3Mike6's Avatar
3Mike6
BTW, ecellent camera work...he captured my best side
Old Mar 14, 2006 | 06:43 PM
  #163
nixer's Avatar
nixer
ill tell you that test isnt doesnt mean anything really. its not a proper or an approved testing method for any weld. an actual test would be to butt up too plates with say an 1/8 or so gap and use a backup strip then remove the backup strip and cut 2 1" wide strips out of the plate and bend it in a press.
Old Mar 14, 2006 | 07:02 PM
  #164
WillyB's Avatar
WillyB
We can do that, if the other's agree it should be done. I don't disagree, just do not know.
But why cut 1" wide strip from the plate? I assume you mean across the weld, or do you mean 1/2 " on either side of the weld? Can you do a quick drawing of what you think we need to do?
Old Mar 14, 2006 | 08:05 PM
  #165
alchymist's Avatar
alchymist
"Mifflin Clay"
I believe it's cut across the weld, and you should be able to bend it 180 deg. without fracture...... The 1 " comes from the amount of force needed to bend it. It's obviously much harder to bend a 4" wide piece, and proves nothing that a 1" piece won't show.
