Group Tech Article Input - Welding
the parts up ( about 400 f) seemed to work for the old farm equip. my dad use to weld for people around home
Welding aluminum in aerospace work is always done using TIG and aluminum rod. No flux is required. Shielding gasses are usually helium and Argon. Unlike MIG, the gasses are usually in separate tanks and mixed at the weld site rather than pre-mixed in one tank.
oh...and if you have ever seen one of Ron Covell's tapes, and paid for it, you will likely feel ripped off. I have his video about working with tubing, and learned absolutely nothing watching it. In fact, it was so boring that I had to ff through much of it. I could only imagine how horrible his welding videos would be.
In other words, if you (for some reason) wanted to use 308, and qualified the procedure using it, then AWS is fine with your using it.
I don't think you would be able to find a metallurgist or welding engineer that would reccomend doing this.
Arc or stick welder (buzz box):
thin steel: poor
thick steel: v. good- excellent
ht steel: no
aluminum: no
SS: no
Disadvantages: requires a nearby 220V outlet, lots of sparks and splatter, welds require chipping of flux.
The proper term is SMAW (shielded metal arc welding), or stick. "Arc" may be the term used often, even in ads for welding machines, but keep in mind that MIG, TIG, sub-arc, and others use an arc also.
TIG (heliarc):
Maybe it’s some term that he uses to make it sound like he’s doing something special.
More comments to add:
Cast metals aren’t what they used to be. Years ago, it was seen as impossible to weld cast aluminum. That’s not much the case anymore, but there’s still some crappy cast parts being made. Most is of much better quality than what we had years ago. I have been successful in welding all cast pieces I have attempted….but the rear stump housing from a Ford truck. I hate to say that here, but it was the case. It kept cracking as fast as I could weld it. I weld one crack and hear another one PING! I have done well welding cast steel with Ni99 tig wire, even without preheat or postheat.
If I was doing body work fulltime, I’d want to use a mig machine, not tig. It gets the weld down fast, with minimal heat input. With tig, it’s a lot slower to put down a tack. It’s easier to control warpage when heat input is kept low.
I have one welding machine at home, and it’s a tig/stick machine. I don’t even own any stick rods though.
Yes, it can hold, but it will not penetrate for a stress situtation. 50% is not good enough. Not even close to good enough under stress.
This thread is for amateur welders. They could get away with downhill on a body panel, but I would never encourage one to try it on a frame or something that will end up with stress on it. We are talking people lives in that situation. I will not encourage someone to do something dangerous.
__________________________________________________ _____________________________________________
Now on to another point. It was brought up earlier in this thread, that the best idea for a frame graft may be to fit it all up and take it to a professional to weld. Why is that? Here is my .02 on it.
Let's use the example of a guy (just like you and I) who decides to swap in an LTD front end on his 53 f-100. He cuts the frame, fits the new one perfectly, welds it all up. It fits great! He finally finishes his truck and takes his family for a drive. He is only doing 35 down a two lane highway when something that he welded breaks. He hits a honda head on killing all inside as well as his 3 year old and injuring his wife. He walks away unharmed. Whos just killed all those people? He did by driving an unsafe vehicle that he welded. If you think his life is bad now (losing a child), just wait until the other families lawyers get finished with him and his wife divorces him and takes most of whatever is left.
Again...thats just my opinion. I see some scary welds on front end grafts and "C" notches online. Not so much here, but people should be warned.
Thanks for your insight, you evidently have had a lot of experience with industrial welding, But others here don't have that background and/or are only amatuers concerned with welding applicable to body work or light fabbing and that's the audience being addressed. I don't feel offended, but would like to comment.
Maybe you felt ripped off by the Covell tape you bought because it was far under your experience, but it doesn't mean that others won't find benefit in it or the others he has put out, since they are geared towards the amatuer with little to no experience. I have been shaping metals for over 30 years as a jewelry craftman, but I found his video "basic techniques for working with steel" to have given me a great deal of information on how to shape, weld and work with sheet steel in body work. I don't believe he has ever produced a video on welding alone.
I find your explanation of the causes of rolled under and undercut bead shape in MIG welding to be diametrically opposite anything I have read or been taught. Perhaps you were refering to TIG?
I"m aware of the origins of the term heliarc and it's outmoded usage for TIG, but it is still is seen and heard in the hot rod field so I included it for completeness.
You're right, I should have said 60 degree included angle not off each side.
It was pointed out later in the posts that a stick welder can be used for aluminum and SS but I still feel it would not be the best choice for a novice to use, especially since hotrodders are typically working with thin materials. Maybe you could do it sucessfully, but I wouldn't choose or recommend a stick welder to weld a SS exhaust system for example.
Hammer welding is a term used to describe the process of reducing shrinkage distortion while welding sheet metal by using a hammer and dolly on the still hot bead to stretch out the shrinkage caused by the weld heat. It's another one of those common misnomers. Speaking of which, what's a "rear stump housing"?
Downhill welds are not allowed according to any engineering drawing that I have ever seen. Any structural engineers on the board?
For a body panel it won't hurt anything, but I am strongly against using a downhill for anything serious. Its up to the writers of the article if they include it for anything else, but my opinion is known. I can't say it any more clearly. Its dangerous.
You are completely correct about "professional welders". That is great advice for anyone.
There is only one shop here locally that I would let weld anything of mine (if I were not doing it myself). And even there, only 2 of the employees would I trust out of a crew of about 20 to weld up my frame. Side note: I am not grafting my frame, just a point for trust.
Just because billy bob (no offence to anyone with that name) has a welder does not mean he knows what hes doing. Ask for references and too see the work. Preferably the welder (or the shop) has done similar work in the past and you can speak to other satidfies or disgruntled customers. Just an a mechanic or body man, or any other service, check them out first.
You always have to stop somewhere in an article or a video, but at least by telling the audience the timing marks need to be lined up it clues you in that there is something I need to get more info on rather than skipping over it completely which may be disasterous for someone following it as their only source of info.
I have not worked in steel fab for a while, but I like to know what everything is. The shop may have them now or the one at the college may.
Your welding procedures are usually only referred to on a drawing. In other words, the specific welding procedure may called for on the drawing, but in most cases, all the specs are kept elsewhere...like in a welding procedure book.
I figured I'd look this up and see exactly what the code says, so we both will know, a well as others that read...
Here's a cut from AWS D1.1 Structural Welding Code:
3.7.1 Vertical-Up Welding Requirements. The progression
for all passes in vertical position welding shall
be upward, with the following exceptions:
(1) Undercut may be repaired vertically downwards
when preheat is ...
(2) When tubular products are welded, the progression
of vertical welding may be upwards or downwards,
but only in the direction(s) for which the welder is
qualified.
So, it appears that ASME and AWS are different on this issue. However, in section 2 above, if the tube was horizontally placed, the welder would have to either start on the bottom and weld each side upwards, or start on top and weld downwards...whichever direction he qualified. I don’t have a copy of ASME code, since it’s probably $10k+.
Would I reccomend a novice weld a life/death bearing item downhill? No. I'd advise them to not weld it at all.
Pull=rollers in the gun
With only rollers at the machine, the drag of wire rubbing the liner becomes great enough that the wire bends between the rollers and the tube that goes to the lead. With the pulling rollers, it helps to pull the wire through and reduce the amount of force the pushing rollers have to do. With a push-pull gun, you have a large spool in the machine, rather than a small spool built into the gun. Miller has a couple out now, called the Edge and Python. They also used to have the "Cobramatic." The XR is another one they sell.
Perhaps Engloid will fill in the blanks here. Please?
There is a 1 year (9 month) college vo-tech programs that teachs welding to high school students in the afternoons. They have a few hours of hands on welding a week. I am speaking of one in particular, but I am sure there are a lot of them.
Almost every student walks out the door "certified" in all sort of positions, materials, and machines. There is no way they spend enough time and get enough experience in those short high school classes to truly know what they are doing and yet they are certified.
Like the acountant thing, I can go online and in probably 10 minutes I can have a dachelors degree in something. Its not worth the paper its printed on, but its legal to have it. If you are going by certifications, look for the names that I hope Engloid can supply. (insert names here)
There are also certifiable welders. Whats the difference? Some customers (refering to a shop) specify that all welds must be performed by certified welders (They usually specify the certifying body).
However, a lot of customers simply require that the welds must be certifiable. If a welder has enough experience and has passed x-ray tests, etc., etc. His welds can be certifiable without the piece of paper saying he is certified. Records of the test he passes must be kept by the company to prove this.
Who would a company do this? simple economics. Its cheaper than the full certification and they don't have to pay an emplyee as much. Guess what...I am certifiable in several materials and positions, but not certified. The shop I worked at only had one certified welder and he came from one of those big welding schools already certified.
On a side note: He truly knows what he is doing.
Therefore, a "certifiable" welder may be one that has shown a history of being able to pass tests...but the employer knows that THEY must test the welder and cannot play on the existing or expired certs the welder has/had. Example: I work at company A, have had several certifications there and on other jobs. I have a history of many certifications. Company B is a place that's hiring people and they must have ASME certified welders. They may look at my resume and know that I have the ability to do the welding, but I still have to pass the test FOR THEM...even if I already have the same cert at company A. In short, look at the term "certifiable" the same you would a person that is able to pass a driver license test, but doesn't have a current license.
It's all a money thing in most cases. Companies don't want to do ASME testing unless they have to. ASME Section IV is the Boiler and Pressure Vessel code. If you make boilers, you will have to work in compliance with it. There are laws that require it, insurance companies demand it. It's very costly to do. Lets say you want to start making and selling compresor air tanks. You can make a 100% perfect weld on them, but wait till your insurance company finds out what product you're making. Your insurance will be cancelled very quickly. IF you decide to do things right and continue making the tanks, you will pay THOUSANDS just to get it all set up. For one, if you're doing ASME coded work, you are supposed to have a copy of the code at your facility. Now, if the AME guys come in and you literally have a xerox copy, they will likely demand payment for a genuine copy, refuse to certify your plant, or sue you for copying their book. It's all a money thing...
But you also have to keep in mind that if you're the welder and you're making pressure vessels in accordance to a certain code, it's only right that you have access to it so you can comply with it. It is also fair for ASME to be upset if they find out you've made illegal copies of their tuff.
