460 radiator options?
Old Jul 9, 2002 | 09:36 PM
  #31
Mil1ion's Avatar
Mil1ion
You could go 70-30 >Coolant to water.<
[font color=red]Dennis
FTE Adminstration
[/font]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
Old Jul 9, 2002 | 11:00 PM
  #32
trinogt's Avatar
trinogt
Dennis: The ground should be attached to the head itself? I will look and see if it is there... If not, I'll let you know, so we can get together for a ground! Thanks.
Mark
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5362&.jpg
Ford started it; Ford will finish it!
Old Jul 9, 2002 | 11:09 PM
  #33
trinogt's Avatar
trinogt
OK... Checked the right head... Nothing there, and I even stuck my hand behind it and felt around for the braided cable... Nothing!
I did find the hood ground strap, though...
Maybe I just need to see it on another truck?
Is it pretty obvious to see? Where on the firewall does it connect, and is there anything else on that connection that shares the ground connection?
Mark
Old Jul 10, 2002 | 12:16 AM
  #34
79Supercab's Avatar
79Supercab
I got a Modig radiator in December from an outfit in California for $325. This included shipping to Washington state and a 5 year warranty from Modig.
I live in the NW (Tacoma area) and this last weekend I went over Stevens Pass (over 4000 ft...) when it was hot (high 80's), loaded for bear with my 10.5' camper and '71 Bronco in tow, and it didn't heat up at all........ It was quite a relief.
Also, I am running an overflow tank, so the radiator can stay full and push water out into the overflow tank when it gets hot, then suck it back in when it's cold. I think this helps a lot also.
Just my .02
Ryan.
78 F250 Ranger XLT Supercab 4x4
460, C6, NP205, D44, D60, 4.10's, 33x12.50x16.5 tires
71 Bronco, 302, C4, PS, PDB
Old Jul 10, 2002 | 01:02 AM
  #35
Mil1ion's Avatar
Mil1ion
>cable... Nothing!
It isn't that technical
Yes
On the Black Flat Part
NO
>Mark
FTE Adminstration
[/font]
[/font]
Old Jul 13, 2002 | 10:05 PM
  #36
trinogt's Avatar
trinogt
OK! Maybe I can finally end this thread!
Today I found my old 160 thermostat. As I put it in, I also swapped a Lincoln 460 thermostat housing with the 90 degree bend in place of the 'straight-up' housing. I did this because my new, larger-type distributor cap was sitting up against the rad hose, making it difficult to adjust ignition timing. I also had to cut down the hose and rotate it at the rad to get the perfect fit from the new housing. I started the truck up, 95 degrees outside (early evening) and went for a drive. WOW! The temp is exactly the same as what my 78 with 351M runs at! About one quarter scale on the gauge! I guess the 195 thermostat reads at three quarter scale. I am willing to bet that a 180 or 185 will put me at or just below 12 o'clock on the gauge. But, I am going to leave the 160 in there, since it warms up very quickly to operating temp, and it is summer. It doesn't bother me to put a 195 back in when the seasons get cooler.
I am so happy!
Now, if only I can cure the rough idle problem when warm... Hmmm
Mark
Old Jul 13, 2002 | 10:26 PM
  #37
Jimbare's Avatar
Jimbare
all alone in the world
Cameo 57
Apr 29, 2014 03:35 PM
Pheadrus
Mar 27, 2014 07:29 AM
Brushwacker
Jul 18, 2011 07:07 PM
merc460
Oct 7, 2002 10:41 PM
