Rad Questions
Old Apr 28, 2014 | 09:16 AM
Cameo 57's Avatar
Cameo 57
Rad Questions
I need to replace my Rad on my 94 F350 2wd, with automatic. In current form, one of the heater hoses runs to a tee from the heater core, then one leg runs to the block, the other to the bottom of the rad. The fitting in the rad has a very small orifice in it. I am looking at a used rad from a truck of the same year, yet it does not have this port. Can I just run the hose to the block or will this cause me problems?
The used rad is also from a manual, so if I use it, I will be running a large after market trans cooler.
Since these seem to be pretty hard to find, would a PSD rad fit? from what year truck?
Thanks
Old Apr 28, 2014 | 10:27 AM
whiteboyslo's Avatar
whiteboyslo
My truck didn't have the tee, but my understanding is that most bypass this anyway with no ill results. Like you said, you'd just need to account for some sort of a transmission cooler.
Mike
Old Apr 28, 2014 | 10:32 AM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
I believe that hose is just to send hot coolant from the engine to the radiator to warm up the trans fluid a little faster. It can be bypassed. Just plug it or eliminate the tee all together with new heater hose. I did it on my 94 when I put in a trans fluid t-stat. You will be o.k. with the aftermarket trans cooler provided it a larger one. I don't think the PSD radiators are compatible. I believe the core support was changed, but I am not sure about that.
Good luck,
Mac.
Old Apr 28, 2014 | 01:19 PM
madpogue's Avatar
madpogue
^^^^ +1; donor truck is probably a manual PSD, with the early PSD cooling system.
Core support is the same between IDI and PSD, but NOT the same as a gasser support.
Old Apr 29, 2014 | 11:19 AM
RA31925's Avatar
RA31925
Agreed, I had to bypass mine (with a bolt in the hose and a bunch of clamps) when I put a Champion on my 94, because I couldn't find a fitting anywhere that would fit that damned Champion radiator. No idea what they used.
Didn't seem to make any difference to my E4OD's performance, even on cold mornings.
Old Apr 29, 2014 | 03:35 PM
Cameo 57's Avatar
Cameo 57
Thanks a lot.
I am going to pick up the used rad on Thursday, for $150 its worth a shot
bballcrf
Apr 30, 2019 08:11 AM
GuitarJesus
Sep 20, 2016 10:39 PM
tje2015
Jul 6, 2012 01:33 AM
LIGOOMBA
Apr 10, 2011 07:19 PM
gumper 123
Feb 22, 2011 08:47 PM
