460 rad
Old Jul 14, 2011 | 08:59 PM
Brushwacker's Avatar
Brushwacker
460 rad
Looks like I'm going to need a new rad for the van, after flushing it the water is now mixing with the ATF. I haven't driven it but the rad level is lower and the ATF level is higher so.... my question is what engines came with the same rad 75-91 ? I've located a cheap new rad but it looks waay smaller then the one in my 88' CW. the local scrap yard has lots of vans, some diesel..will they fit? can you bypass the rad and just run the stock atf cooler? thanks
Old Jul 18, 2011 | 07:07 PM
Brushwacker
Has anybody just used the auxillary cooler for the trans ? will it provide enough cooling? my rad has an internal leak and was thinking of bypassing the atf section?
Brushwacker
Jul 20, 2011 12:03 PM
Mr. Bob
Jul 18, 2006 09:08 PM
rpokorny
Aerostar
Jul 7, 2004 12:02 PM
351 power
Nov 11, 2003 06:19 AM
