460 radiator options?
Old Jul 4, 2002 | 03:47 AM
Jermafenser's Avatar
Jermafenser
Does the cooling system hold pressure? Flows properly?
Old Jul 4, 2002 | 08:53 AM
mick460's Avatar
mick460
Not 100% sure on this but some 351's had a relief hole in the thermostat. I know Clevelands need it. Small 1/16" hole right in the thermostat is all it is. Double check this as I have had to replace head gaskets and a cam because I did not have the correct thermostat.
Old Jul 4, 2002 | 06:32 PM
trinogt's Avatar
trinogt
I have 3 different thermostats for my 460 now, all different makes and temp. None of them have a relief hole.
The system is holding pressure: When I shut the truck off, the top rad hose is hard.
Just bought a sending unit today; gonna try it out later.
Mark
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5362&.jpg
Ford started it; Ford will finish it!
Old Jul 4, 2002 | 07:54 PM
Mil1ion's Avatar
Mil1ion
Mark, After you check that out.
Look for the braided ground cable from the engine block to the firewall.
There should be one.
[font color=red]Dennis
FTE Adminstration
[/font]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
Old Jul 4, 2002 | 09:49 PM
trinogt's Avatar
trinogt
Well, the trip to Banff was a success. Even though the gauge read almost at the top, when I shut it off in town, there was no overflow happening. I came back and bought a sending unit from Ukrainian Wire. I installed it and fired it up. The gauge now reads about 5/8, a far cry from the top of scale! I guess the old unit was sending too little resistance for the amount of heat there. I wonder though:Is the center of the gauge typical for a big block with a new rad and a 192 degree thermostat? I am happy that at least she isn't overheating. I was lucky that I didn't have a complete boilover at any time!
Now I have to turn the mixture screws back in a little to lean it back out to where it was. (another safety measure)
Thanks fellas!
Mark
Old Jul 4, 2002 | 10:03 PM
Mil1ion's Avatar
Mil1ion
Living in Calgary you know how much the temperature can fluctuate at any time of the year.
The real test is driving home on McLeod Trail at 4:00 pm on the hottest day in August when it's bumper to Bumper traffic.
Or do you live in the NW ?
There are too many variables when it comes to temp gauges.
Mark,You did get the sending unit for a gauge and not an idiot light,Right?
FTE Adminstration
[/font]
[/font]
Old Jul 5, 2002 | 09:48 PM
trinogt's Avatar
trinogt
I live in SE, Mckenzie Lake.
I asked about the gauge, and the guy said there wasn't any other option for the sending unit on that particular truck and with that motor except for gauge-type. What am I looking for on engine block ground strap? Poor connection?
Mark
Old Jul 6, 2002 | 12:47 AM
Mil1ion's Avatar
Mil1ion
There should be Flat braided cables going from the Hood to the Firewall > From the Engine Block to the Firewall.
The one on the hodd gives a good ground for Hood light.
The engine to firewall cable gives a good ground for Sending units as the insulatprs on the block isn't a good ground.
FTE Adminstration
[/font]
[/font]
Old Jul 6, 2002 | 02:55 AM
trinogt's Avatar
trinogt
Ahhh... I see! Thanks Dennis, I'll get on that tomorrow! I just had to fix my wife's car. She ran it quite low on oil (apparently girls don't check oil) and collapsed a hydraulic lifter. It wouldn't pressurize again, so I removed the culprit and took one from my spare motor (Nissan CA20E, 4 cylinder) and replaced with that. It pumped up in no time, so I put it all back together and told her to ALWAYS check the oil once a week! (it has been using oil for a while now) She was lucky this time: could have been much worse! The cam seems ok, and the rockers.
I guess it is time to do the valve seals. I hope the rental spring compressor is tiny enough to get in there: Not much clearance around those aluminum cylinder heads! I believe that to be my main cause of oil loss. Compression is 150-155 on all 4.
Mark
Old Jul 9, 2002 | 01:41 AM
trinogt's Avatar
trinogt
Guess what??? I don't see a ground strap from the block anywhere! Where should this be located? I see on my other truck (78) the one for the hood light, but not even that on the 76 in question! I can always grab one from the wreckers... Just need to know where to look for it? Is it right side of block, rear?
Mark
Old Jul 9, 2002 | 02:00 AM
Mil1ion's Avatar
Mil1ion
On the back of the right bank head and to the firewall.
I have an extra one if you can't find one.
FTE Adminstration
[/font]
[/font]
Old Jul 9, 2002 | 06:56 PM
BigJake86's Avatar
BigJake86
I just transplanted a 460 into my '78 F-150. It had a 400 in it. Will the 460 run at a normal temperature with the original 400 radiator? I probably won't put a thermostat back in the motor until winter.
Old Jul 9, 2002 | 07:51 PM
  #28
hillbillyk's Avatar
hillbillyk
I just put a slightly modified 460 in my 78 crewcab, I used a 195 thermostat, and a good 400 radiator, no problems yet. she runs right in the middle of the scale, it climbs a little when I am in traffic sitting still in 100 degree weather. Works good.
Old Jul 9, 2002 | 08:38 PM
  #29
Mil1ion's Avatar
Mil1ion
It depends on where you live and the temps.
It should run cool enough.
Why are you running WITHOUT a thermostat?
It should have something in there to run close to the proper temp.
FTE Adminstration
[/font]
[/font]
Old Jul 9, 2002 | 08:45 PM
  #30
BigJake86's Avatar
BigJake86
Well, since the 460 is in my farm truck, it will either be pulling a cow trailer, hauling hay, pulling equipment, or just about anything else when it is running. Therefore, the temp. will get warm regardless of the thermostat not being there.
