460 mpg question
Old Jun 29, 2007 | 01:26 AM
  #91
darrin1999's Avatar
darrin1999
my 1978 f250 4x4 when i finally finish it will be a 460 stroked to 545, with a dual quad intake, running twin 425 impco propane carbs, about 12-1 compression, retrofit hydraulic roller cam and lifters, and will get about 4-6 mpg of propane and push about 500 horse and 650 ft-lbs torque... now thatll be a fun truck- until i have to fill it with gas
Old Jun 29, 2007 | 01:31 AM
  #92
darrin1999's Avatar
darrin1999
a 94 would be an e40d... computer controlled... so the computer may have just been reprogrammed too. lots of modifications could have been done in 13 years
Old Jun 29, 2007 | 01:32 AM
  #93
LoneRebel's Avatar
LoneRebel
one day i will build one like that....its going to be a while though, i have three trucks and a car. too many too maintain let alone rebuild one
Old Jun 29, 2007 | 01:34 AM
  #94
LoneRebel's Avatar
LoneRebel
my best bet is too take it down to Ford dealer if my tuneup dont help. they should be able to tell whats wrong. Well i will post my results tomarrow right now im going to hit the hay. thanks for your advice i will keep you posted.
Old Jun 29, 2007 | 01:37 AM
  #95
darrin1999's Avatar
darrin1999
any idea what the rear end ratio is?
Old Jun 29, 2007 | 01:38 AM
  #96
darrin1999's Avatar
darrin1999
no problem... have a good one i hope you get your mileage goal
Old Jun 29, 2007 | 01:39 AM
  #97
LoneRebel's Avatar
LoneRebel
no clue. one of theese day i might pull off the cap and find out....or i'll just look it up its probably stock. it was just a work truck
Old Jun 29, 2007 | 12:49 PM
  #98
Justin460's Avatar
Justin460
i have a 1991 460 with headers k&n and throttle body spacer with 3.55 gears E40d trans and 35 inch tires i get 10.5 every day no matter how im driving the reason that im getting 10 and some people are getting 8 or less is because i have an E40d trans and the 3.55 gearing also the k&n filter gave me two mpg however the headers and spacer gave no mpgs and i also throw in a bottle of injector cleaner every thousand or so miles which helps
Old Jun 30, 2007 | 10:26 PM
  #99
f350mothatrucker's Avatar
f350mothatrucker
I HAD an '86 F350 single cab dually with a C6 and 4.10's and no matter what I did I got about 7mpg. On the plus side, I put an edelbrock performer 460 intake on it and rebuilt the factory carb and it pulled a 9.9 in the quarter :-) On the down side, it didnt take long before I bent 12 of the 16 pushrods and oil circulation issues did the rest :'-(
Old Jun 30, 2007 | 11:01 PM
  #100
darrin1999's Avatar
darrin1999
"it pulled a 9.9 in the quarter " you mean the 1/8th right? no possible way that it would get 9.9 in the quarter without lots of nitrous, a blower, and/or a stroker kit, unless you mean the quarter kilometer
Old Jul 1, 2007 | 02:56 AM
  #101
f350mothatrucker
No, I definitly meant a quarter mile. I don;t know what was done to it, I bought it as a womped out old horse puller, adn with minimal work it used my head to crack its back window when I used too muck gas.... If i could figure out how to insert a picture I'd show you one of the old girl turning her 4 rear tires into smoke :-)
Old Jul 1, 2007 | 03:07 AM
  #102
darrin1999's Avatar
darrin1999
do you have any idea how much power it would take to push a 5000 lb truck to 9.9 in the quarter mile? more than even monserbaby's race truck puts out, and hes at about 900 horse with a 528 stroker, custom solid roller cam, 14-1 compression and race gas
Old Jul 1, 2007 | 03:12 AM
  #103
f350mothatrucker
As a matter of fact I do, it was a f*in beast! but really there wasnt anyhitng too special about the engine, it was just a 460, headers intake, cam and rebuilt holley 800 up there... I always attributed it to the C6 and gearvendors combo
Old Jul 1, 2007 | 12:27 PM
  #104
Bear 45/70's Avatar
Bear 45/70
This has got to be the biggest bunch of I've seen in quite a while. A 9.9 sec. 1/4 mile truck would be next to unstreetable and totally worthless as a tow vehicle.
Old Jul 1, 2007 | 01:32 PM
  #105
f350mothatrucker
There's the beast before her new body, She looks like a pile, but fiberglass took care of that problem :-)
