Steering stabilizer..
Old Sep 3, 2005 | 12:22 AM
pfogle's Avatar
pfogle
Hey all, I'm looking at putting a steering stabilizer kit on my '88 E150CW.... It's napa part number NSSA1930..... Anyone here use a similar kit? Thoughts, advice?
Old Sep 3, 2005 | 03:55 AM
Crash687's Avatar
Crash687
save your money. I have yet to ever have a need for a steering stabilizer for vehicle that did not have oversied agresive tread tires. not one of the 1 ton work vans that I have personally logged close to 400,000 miles on, have I felt a need for a stabalizer either.
Old Sep 3, 2005 | 12:36 PM
pfogle's Avatar
pfogle
This thing has a/t 6 ply tires all the way around, and drive like it's on marbles.... We've checked or changed most of the front end parts, and the alignment is correct. It just wanders all over the road. It's been about 5 years since I drove this thing, so learning to respond to it is going slow.
Old Sep 4, 2005 | 11:02 AM
Fordcr's Avatar
Fordcr
The best thing I did for my 150 was the XL tires. If the door plate says it. It means it. 35lb tires are not built the same.
Old Sep 4, 2005 | 09:09 PM
pfogle's Avatar
pfogle
These things are ~55psi tires, they are very aggressive tread HD XL tires... these things are 6 or 8 ply. Very tough. It's just real loose.
Old Sep 5, 2005 | 01:15 AM
haroldservice's Avatar
haroldservice
did the '88s have i beam front ends? they can be a real bear to setup correctly, need an old timer or a suspension guy that studies.
Old Sep 5, 2005 | 10:11 AM
pfogle's Avatar
pfogle
Indeed it does, my dad is an old timer and has worked on this front end for many hours to get it as good as it is. It was much worse. He said it's "the nature of the beast" and a stabilizer will help.
Old Sep 5, 2005 | 02:03 PM
haroldservice
i put power steering on my van and a stabilizer really helped calm it down. i am no engineer but it feels like the power steering on these vans is a little bit to sensitive.
Old Sep 5, 2005 | 08:16 PM
maples01's Avatar
maples01
A steering dampener is for the jerk eperienced when you hit a pot hole and that is all, it's a shock to absorb feedback. I can't tell you how many 4x4 owners think they need them beacuse play or slop in the steering and what not, worn tie rod ends, bushings or steering box is generally the cause, a dampener will not fix this.
The camber set up on your front end will affect the way it feels when steering or just driving straight ahead, it also affects tire wear, so the designated setting is a happy medium between the two. If you discuss it's driving characteristics with the person aligning it, maybe they can adjust it to correct it.
If you're experiencing bump steer when hutting pot holes or on rough terrain, add one, if not, try to find the worn component causing it.
Old Sep 5, 2005 | 09:20 PM
Wiskey6's Avatar
Wiskey6
Today was the first time ever in a Ford Van that I even thought about a stabilizer.
It was on a wash board road. I was VERY surprised how the tires and steering wheel bounced back and forth.
Funny thing is, I just had the steering box and one tie rod end replaced under warranty.
Before that I had been on roads like these today, and the only thing it did was get loud fom the rear end suspension!
Old Sep 6, 2005 | 09:56 PM
pfogle's Avatar
pfogle
Maples, there is no SLOP, or looseness in the wheel. The steering is very responsive. It wanders, the front end is almost impossible to align, so the damper would indeed help as it would keep the wheels from moving at will.
Old Sep 6, 2005 | 10:12 PM
maples01's Avatar
maples01
Many people put them in under false pretenses, that's what I wanted to put out there.
I want to lift mine 2" and go with the wider 33" tires, would most likely require a dampner.
hasteranger
Jan 9, 2017 01:25 PM
smiley87
Apr 13, 2015 10:05 PM
pjhjah
Jan 23, 2010 07:55 PM
vento
Dec 4, 2009 01:00 PM
Drawsoncad420
Jun 13, 2002 04:43 PM
