Hello my vans cruise slowly stoped working. Before it quit competely it was very slugish and would not hold speed. Slowing going up hills and speeding comming down. I have no lights on the dash. I have jumped the brake pressue switch. The van only has 195,000 miles and the cruise is used daily. I cleaned the connection to the servo asembly. Any help?
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Do you know that there are 2 switches, the brake master cylinder has a back up cut off switch for the cruise control as the main cut out is on the brake pedal inside. I know about the one outside because it is the switch responsible for all the truck fires, I don't have a clue how the van's differ enough to not have any burning, but I located it on mine.
Found the problem. I removed the cover on the servo and found the drive motor tied up. Found one of the same style on e-bay. It looks like I may have to change the cable.
