I have a 1991 Ford Ranger 4x4 with a 5 speed and I would like to locate the neutral safety switch.
Symptoms are when you push the clutch and turn on key nothing happens.
I jump the solenoid on the firewell and the truck will start.I thought the solenoid was the problem and purchased a new one but nothing changed when I installed this. This is why I feel the neutral safety switch may be faulty.
Any ideas or can someone tell me exactly where the switch is located so I can jump this out and check it.
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Good question. I dont have a wiring diagram for a 91. You should be able to find an online wiring diagram at autozone.com or your Haynes manual should show it.
