Wiring ID at Connector to Neutral Safety Switch
I have a 87 F150 with auto trans. The harness has been hacked up and the connector to the neutral safety switch and the neutral safety switch is gone.
I belive these wires are for the starter relay and the back up lights.
Can someone please let me know what each of the colored wires at the neutral safety switch are for? i.e. which are for the starter relay and which are for the back up lights. so that I can splice the correct wires to the new neutral safety switch when I pick one up.
Thank You.
Thank You.
on
The speed sensor wire Red/light blue, basically goes to ground than computer pin number 6, the other Dark green/white tracer is pin 4 in the ECM So the red/blue wire turns black by the time it gets back to the ECM. Thats the speed sensor, The starter relay wire is red/light blue tracer should be 2 that goes to the starter relay, it doesnt matter the polarity, 1 red/blue comes from ignition switch, the other red/blue goes to start relay and to the distributor. purple/orange and black/pink are the reverse lights. purple is power and the black goes to the reverse lights. If you have a red/white that goes to the shift control module? My mind is melting
Bulldog187th
24
05-28-2020 08:51 PM
Jeff Lambrecht
03-16-2008 11:07 PM
