Sponsored by: Kumho
Smaller Tires
Old Jul 13, 2005 | 12:10 AM
bigdaddyII's Avatar
bigdaddyII
Question Smaller Tires
I had a set of 4 new tires given to me by my dad when we went to visit him this week. The only problem is that the tires are a little smaller than was on my truck. The size that was on there were 235/70/r16 and the ones that were just put on there are 225/75/r16. Not to much of a diffrence, but how would this affect my speed calibration, and will this minute size diffrence affect anything else such as gas mileage? The gear ratio on my truck is 3.55. Thanks in advance.
Old Jul 13, 2005 | 01:50 AM
RomerB2's Avatar
RomerB2
It's going to affect it a little bit but not enough really to matter. It will change your MPG but, only because you'll be not reading the right callibration and it will set your equasion (sp?) to be wrong. You'll be going slower than what your speedo says.
Old Jul 13, 2005 | 11:08 AM
460's Avatar
460
Your new tires, the 225/75/r16, are just a little taller than your old tires, the 235/70/r16. The "theoretical" height of your old tires is 29", and your new ones are 29.3"
It's possible that they may be the same height in real life though because when companies manufacture tires they are usually just a bit different in actual size from the stated size on the side wall. I think the height of the two sizes you have listed are close enough that you won't even notice a difference.
Here is a calculator you can use to figure out your tires height and width http://www.tyres1.com/calculators.html scroll down to "Metric Tire to Inches Conversion"
Old Jul 13, 2005 | 03:24 PM
bigdaddyII's Avatar
bigdaddyII
So the new tires are a bit narrower and not enough taller to make a diffrence? Thanks for the info guys, 460, that calculator was really helpful.
DonEssig
2004 - 2008 F150
Jan 19, 2014 01:59 PM
Redneckfordf2502002
Apr 11, 2012 08:06 PM
Vinford
Jan 9, 2011 08:58 PM
FordF100man
Feb 26, 2008 05:40 PM
bansheeboy182
Oct 13, 2002 10:44 PM
