Would different sized tires affect a transfer case?
Old Jan 15, 2014 | 03:29 PM
DonEssig's Avatar
DonEssig
If two of my front tires were different sizes, would that affect my transfer case? My truck is a 2006 F150 with 4 wheel drive. What other damage could it cause?
Old Jan 15, 2014 | 06:49 PM
1saxman's Avatar
1saxman
Generally you have to be careful to have equal diameter tires on all four wheels with any kind of 4WD or AWD. It wouldn't hurt anything as long as you don't use 4WD, or if you are careful to only use it on slick/loose surfaces where the wheels can spin a little to shed the torque build-up from the unequal tires. Otherwise you can quickly destroy a transfer case.
Old Jan 19, 2014 | 01:59 PM
1saxman's Avatar
1saxman
I thought maybe I should explain further. With different diameter tires on one axle, you have 'stagger' like a race car uses to help it corner. When turning a corner or just going around a curve, the front and rear axles make differing amounts of revolutions. You can imagine what happens when you do this with 4WD locked in - something has to give. On slippery/loose surfaces, the tires are free to slip and relieve the torque build-up. But on dry surfaces, it would continue to build up until something breaks.
UglySinceBirth
15
Feb 15, 2010 12:01 PM
loudford
Jan 19, 2009 09:58 AM
dannielchackas
Dec 18, 2008 05:04 PM
GOT NOS
Nov 26, 2002 11:21 AM
