Sponsored by: Kumho
squeak.....huh??
Old Jun 3, 2005 | 07:14 AM
bigdaddyII's Avatar
bigdaddyII
squeak.....huh??
I replaced my upper/lower balljoints as well as tire rod ends a few months ago, and a couple days ago I noticed a squeaking noise coming from my left front when I hit a small bump or road variation. It only does this when I hit small bumps and no other time, not even for the big bumps. When my tire rods were going out a few people told me that in relation to the classic popping noise a bad ball joint will also make a metallic "bing" over bumps, is this something I should worry about? This noise does not sound metallic, it sounds like rubber rubbing. And it only started (that I noticed) after a rain a couple days ago. I changed my shocks about 2 months ago as well, would this have anything to do with it?
Old Jun 5, 2005 | 10:28 AM
bigdaddyII's Avatar
bigdaddyII
anyone??????
Old Jun 23, 2005 | 09:50 PM
shovelhead1's Avatar
shovelhead1
squeak
hey bro,probably not your problem but i once traced a similar sound to a body bushing.if you can cause the sound to occur predictably a can of silicone spray and some trial and error will find it regards shovelhead
Old Jul 13, 2005 | 10:49 PM
cvo's Avatar
cvo
Lube the sway bar bushings, should quiet down for awhile. Mine does the same thing.
06powerstroker
Jun 26, 2013 12:43 AM
06powerstroker
Jun 25, 2013 10:09 PM
snoopt1
Jul 2, 2011 01:50 AM
alz
Oct 1, 2006 04:54 PM
fawey1
1983 - 2012 Ranger & B-Series
17
May 8, 2005 09:46 PM
