18k mod?
Old May 3, 2005 | 09:08 PM
ktahelton's Avatar
ktahelton
18k mod?
im lookin for more info on the 18 k mod...can anyone help!
Old May 3, 2005 | 09:51 PM
pdkloste's Avatar
pdkloste
Don't know.... put 18k ohms worth of resistors in... instead of the 10k.
From what I have gathered from reading on this forum, it will give you less fuel pressure increase than the 10k mod. If you are wanting an increase, you need to put a smaller resistor in... I think... search for 5k mod, clamp mod, etc.
Old May 3, 2005 | 10:00 PM
bigdaddyTank's Avatar
bigdaddyTank
There are versions of the 18k that are adjustable. blackclouddiesel.com sells a 18k mod that uses a variable resister to adjust the ICP. They claim up to 65hp-120ft pds with it set to max. comes with a throttle activation setup to shut off when the throttle is lifted to elimanate any surging at idle and still work with the cruise on.
Old May 3, 2005 | 10:04 PM
Pocket's Avatar
Pocket
18K mod is the name for the commercial ICP mod (10K). It is sold by Blackclouddiesel.com. It's an adjustable 10K mod and if you get the IVS switch, then it only comes on when you depress the accelerator pedal and cures the rough idle when turned up. It's a 3 position switch with off, low, and high, and an adjustable dial to set the resistance level where you want it. Some people with just the 10K mod only have problems with a rough idle, and can't adjust it at all without removing the resistor and replacing it with a different one.
More expensive than just a resistor, but more adjustable and driveable for some folks.
Old May 3, 2005 | 10:05 PM
Pocket's Avatar
Pocket
Tank beat me.
Score: Tank 1, Pocket 0
You may have won the battle, but I will win the war
Old May 3, 2005 | 10:09 PM
pdkloste's Avatar
pdkloste
I just put a reed switch on the Idle Validation Circuit to activate the 10k mod..which eliminates the surging at idle. Cost me a whole 99 cents more and about two minutes of work. I can still shut it off w/a toggle... don't have a problem w/ cruise control... although I usually cut off the 10k on long highway runs. JMO
Old May 3, 2005 | 10:17 PM
bigdaddyTank
Nice try.
Have you seen the new version of the 18K that blackcloud has? It looks like they did away with the toggle switch and added a throttle control that works with the cruise. Everything is now in a nice little box, pretty nice setup. $85 sounds like alot for somthing you can make cheaper, but its not bad considering all you have to do is hook it up.
Old May 3, 2005 | 11:27 PM
7.3whitemonsta's Avatar
7.3whitemonsta
i dont fullly understand this 18k mod what does it do? how does it work, what kind of difference is it, can i do it for cheap? if so how can it be done? thanks
Old May 3, 2005 | 11:33 PM
kalsc's Avatar
kalsc
This type of mod is referring to jumping a resistor across two of the three wires for the injector pressure sensor on the driver side head. This sends a signal to the computer of a 'lower' pressure which in turn the computers ups the fuel pressure and dumps more fuel into the engine. I tested out a 10K ohm resistor and a 5.6K ohm resistor, I love the latter, I have the circuit running with a toggle, sure makes the truck lop at idle and when I switch it on under acceleration, even with my Diablo 3 position flip chip, I feel the extra grunt kick in.
Here's some more info:
http://www.forgotton.net/mods/indexframe.html
Old May 4, 2005 | 08:41 AM
pdkloste's Avatar
pdkloste
No Bigdaddy, I haven't looked at the blackcloud unit yet..
Now that you have peaked my interest, will have to look at it. $85 doesn't sound too bad...
I think my grand total for the 10k mod I put in was $8.67.... I had to buy wire, toggle switches, wire taps and a reed switch along w/resistors.
The only thing that I might mention to Ktahelton is that you may want to try this cheaper version to see what you think before buying the built box.
Old May 7, 2005 | 01:49 PM
k2vailkid's Avatar
k2vailkid
Question
Pardon my ignorance, can these mods be stacked with a Diablo programmer, or does one cancel out another, etc...........................
Old May 7, 2005 | 03:16 PM
kalsc's Avatar
kalsc
I have the 5.6 and 10K mod stacked with my Diablo Flip Chip, works awesome! Your programmer obvisously works in reprogramming the computer (much like the flip chip) except you can specify parameters. So, what ever program your computer is running on, applying the IPC mod works independent of all that. Even in the performance setting of my Diablo, when I turn the 5.6K mod on, I definately notice it. Hope this helps a little.
TIUSER
Aug 26, 2014 04:13 AM
classic.rocker978
Jun 20, 2014 09:33 AM
bad ass diesel
19
Feb 9, 2014 04:20 PM
coreyallan01
Jan 25, 2014 02:59 PM
1997f350stroker
32
Dec 3, 2009 07:40 AM
