Code 29
Old Mar 1, 2005 | 01:46 PM
eldomike's Avatar
eldomike
Code 29
My van has been dropping out of lock up some lately(not all the time)...ran the codes and got a 29 and 56..do I need to replace the switch at the tail of the tranny and the one in the rear end?
EldoMike
91 Ford E350 7.3L
Old Mar 1, 2005 | 10:04 PM
PLC7.3's Avatar
PLC7.3
The 29 is insuficient input from the VSS does the speedo run steady or bounce around.
The 56 is the TOT Transmission operating temperature sensor on the solenoid pack in the trans.
Old Mar 1, 2005 | 10:40 PM
yooper00's Avatar
yooper00
Where do you get a tester that tells you the codes?
Old Mar 2, 2005 | 12:36 AM
PLC7.3's Avatar
PLC7.3
Wallymart..........
Old Mar 2, 2005 | 06:48 AM
eldomike's Avatar
eldomike
speedo runs steady....though it has always been 15% off....so I guess I'll get a new VSS....
a friend owns a tranny shop did the codes for me...I checked the local Walmart, they don't carry the code readers any more...
Old Mar 2, 2005 | 08:45 AM
PLC7.3's Avatar
PLC7.3
If your truck has the speedo in the side if the trans you probably need a different gear color to compensate for something IE rear axle gear ratio change or different sized tires. Sort that out first before changing parts...If the gear is worn that will screwitup 2........
If you have changes the above tires or gear ratio and have the electronic dash you need to reset the speedo with the change or the trans will not work correctly as the PCM gets false info and tries to run with it in both cases.
Old Mar 3, 2005 | 05:07 PM
eldomike's Avatar
eldomike
picked up a VSS at NAPA for $29 and change...took about 10 minutes to change...everything seems to be alright now...thanks everyone for the advise...this is surely a great Forum!
eldomike51
Apr 4, 2012 08:42 PM
eldomike
16
Apr 10, 2007 11:02 AM
eldomike
20
Sep 24, 2004 10:14 AM
eldomike
Aug 30, 2004 06:08 AM
eldomike
Jul 1, 2003 10:55 PM
