Latest problem - processor ?
Old Mar 1, 2005 | 05:29 PM
trike1946's Avatar
trike1946
Question Latest problem - processor ?
I have a 90 E350, 7.3, E4OD (just rebuilt last month). It started to give me trouble today shifting from 1st to 2nd. I used low, 2 and then D, and got it to the place that did the trans. He checked the codes and said it was the processor. By the time I got it to the shop it was acting normal. When he drove it there was no problem. Murphy's law I guess. Anyway, what is a processor? Will it cause the trans to shift strange, and where is it. I just installed power windows, could I have done something to it? He is getting it from Ford for $290, is that good? Also since the trans has had all the upgrades, should it have mercon V? Thanks for any help.
Old Mar 1, 2005 | 05:48 PM
RawPower's Avatar
RawPower
What upgrades does it have?
Old Mar 1, 2005 | 06:06 PM
trike1946's Avatar
trike1946
He said there were some in 95 and I am not sure what else. It seems to be a reputable shop. Been there for many years. Other people I know had work done and were satisfied. I tow alot so I am hard on the trans I guess.
Old Mar 1, 2005 | 06:20 PM
RawPower's Avatar
RawPower
I dont follow the 95 thing....
Are you saying upgrades from the factory, cause then they arn't upgrades, they are just factory improvements. Then you just follow what the book says.
I cant help you on the processor, Im into manuals. I can tell you that E4OD's blow a lot, and break all the time...
Old Mar 1, 2005 | 09:49 PM
PLC7.3's Avatar
PLC7.3
Before the tech changes the Powertrain Control Module if that is what you mean, get him to reset the FIPL (TPS). I/We have not heard any change for the E4OD to Mercon V in fact just the opposite remain with Mercon-Dexron111 is recommended by Ford.
What code # did the trans set.......
Old Mar 2, 2005 | 05:10 AM
trike1946's Avatar
trike1946
I will find out what the code # was. How do you reset the TPS?
Old Mar 2, 2005 | 06:24 AM
trike1946's Avatar
trike1946
I did a search and found out how to set TPS. I will still find out the code. Thanks for the help.
Old Mar 3, 2005 | 06:04 PM
trike1946's Avatar
trike1946
I got the van back today. The processor was the original. There was a recall in 92 and some changes after that. The new one from ford has a slightly different number. It was under the heater in a black box. What genious designed an electric gizmo to be under a potential water leak. Anyway they also checked the TPS and it was ok. The van shifts fine so I guess I will have to wait and see. Now I can get back to work anyhow. Thanks for all the help.
FlyCanadianGuy
Alternative Fuels, Hybrids & Mileage
Dec 11, 2008 10:41 PM
tjbeggs
Bio-diesel, Propane & Alternative Diesel Engine Fuels
18
Jul 22, 2008 07:27 PM
tjbeggs
25
Jun 17, 2008 09:47 PM
captaincook
Jun 27, 2007 10:38 PM
Murphy2000
Jun 15, 2007 01:21 PM
