Turn the key, get a click. Battery power is good. Jump start doesn't help. Jumping the relay terminals doesn't help. I think the click I hear is from the solonoid on the starting motor.
Could it be anything BUT the starter at this point before I pull it and get a rebuilt?
99% sure it is your starter. Clicking noise is tale tail sign that the starter is toast. You can always bang on it with a hammer and try starting. That at least will get you to a mechanic if need be.
I didn't have time to do the starter today and "someone" is down my back about getting it running so I used the free towing service with the insurance co. to take it to the Starter & Alternator place around the corner.
They say it starts like a charm every time they try it, can't find a problem.
I got nothing out of it for several days and I am sure to have it crap out again when I least expect it.
What else could it be?
It either doesn't budge or it starts like a champ. This is driving me nuts.
It's probably like most of us going to the dentist. It might hurt like heck before you get there, but the moment you are there, you are so scared the pain goes away
The starter on my 92 4.0 AWD started to fail first when the engine was hot. i.e. if you drove around, stopped, then tried to start the car a few minutes later, nothing. But if you waited for an hour or so for things to cool down, it started right up. I'm suprised that the Starter Shop didn't check that.
I saw the same problem with the starter on a friends 8x 3.0 v6 Sable. The warmer the engine got the slower it would crank, just like the battery was low. It started right up in the morning, and after sitting in the parking lot all day no problem.
Whenever you replace the starter motor, it is alwas a good idea to replace the solenoid too, since a faulty starter can overload the solenoid, and they therefore, tend to both go out at about the same time. It doesn't go the other way around. A faulty soleniod will not usually wear out the starter motor (unless it's been arching)
