How much boost??
Old Feb 5, 2005 | 10:33 PM
  #31
Z-MAN's Avatar
Z-MAN
Idle 0 Psi
Wot 28-34 Psi W Six-gun And Speedloader Bundle
Old Feb 6, 2005 | 12:03 AM
  #32
smokin_6.0's Avatar
smokin_6.0
Choctaw how difficult was it to hook up your gauge in the map sensor line and where did you get it from? Does removing your egr valve change the reactions of your guages at all??
Old Feb 6, 2005 | 08:44 AM
  #33
Bigdawgkp's Avatar
Bigdawgkp
bigdawgkp
I do not get boost at idle either. 2005 SD FX4
Old Feb 7, 2005 | 06:58 PM
  #34
Brian460's Avatar
Brian460
Originally Posted by Brian460
I would have to agree that at very little boost or none it will depend on the guage. I have an X-Monitor and mine shows .3-.9 at idle 35.9 at max.
I did that wrong that figure is idling in gear, in park or neutral I have 0.0.
Old Feb 7, 2005 | 10:26 PM
  #35
SBV45's Avatar
SBV45
Where you place the connection is going to make a difference. If you have no manifold boost, that means your turbo is putting out some boost or you would have vacuum in the intake manifold.
Old Feb 8, 2005 | 06:04 AM
  #36
Bigdawgkp's Avatar
Bigdawgkp
bigdawgkp
Point well taken SVB45. The gauge on the dash shows no boost at idle. The gauge may not be accurate enough to see on the dash.
Old Feb 8, 2005 | 09:32 AM
  #37
Choctaw Bob's Avatar
Choctaw Bob
It was an easy hookup, just cut the line and install a T from a hardware store.
Unplugging the EGR had no affect on boost that I have noticed.
Old Feb 8, 2005 | 11:12 AM
  #38
TinyOne's Avatar
TinyOne
2005 F350 6.0
idle 800 rpm no boost registers
50 mph about 2 lbs
60mph about 4 lbs
3.73 gears
Old Feb 8, 2005 | 11:38 AM
  #39
PSD6litre40's Avatar
PSD6litre40
My truck has started boosting 1 - 1.5 PSI at idle since I changed exhaust and filter.....
Old Feb 8, 2005 | 01:59 PM
  #40
Bigdawgkp's Avatar
Bigdawgkp
bigdawgkp
PSD6litre40 - You have my attention, please elaborate on your changes! Excuse my ignorance, but what truck do you have? Thank you-bigdawgkp
1L243
13
Apr 5, 2013 10:25 PM
Brett1989
Oct 1, 2008 09:43 AM
2 stroke man
Jan 3, 2008 07:31 PM
firemanbird
Aug 9, 2006 10:34 PM
resqdawg3
Sep 29, 2003 10:31 PM
